Help - Search - Members - Calendar
Full Version: Flexi-Glass Windows for Mk3: updated with details
Club Polo Forum > Classified Ads > Parts For Sale > Group Buys
bigstu
Just had an emai from Paul at Plastics4Performancel about Flexi-glass windows for mk3 polo's being made.
QUOTE
Hi Stu
I have priced you for the windows in our 4mm thick clear FLEXIGLASS
Rear screen @ £55.00 + VAT
Rear 1/4 windows @ £35.00 + VAT each
Total of £125.00 + VAT
UK Mainland delivery is £13.00 + VAT
For group buys we require a minimum of 5 where you will recieve a 10% discount, 5-10 @ 13% discount, Over 10 @ 15% discount
Paul Davenport
This is just a guaging interest post to start with, but will look to go full swing with enough interest
Cheers, Stu
Tav
This sounds up my street, are the windows just fitted into the rubbers as the original OEM ones would have been? Obviously rear one is just bonded onto the hatch
bigstu
Being 4mm thick they are about the same thicknedd as normal windows so they should fit straight into the rubbers. but i will be able to double check for you
Tav
Excellent, I emailed them about are year or so ago to get a price and they were quite prompt to get back.
tobyk
Does the group buy only apply to Mk3 Polo stuff because I'd be up for Mk2 Golf stuff!
bigstu
QUOTE(tobyk @ Sunday 20th July 2008 - 4:29pm) *
i will check to see if i can order other models in
tobyk
Cheers mate
I'd take all 3 rear windows with possible interest for front door windows if they will do them.
Thanks,
Toby.
bigstu
front doors will be available, will check prices for you
joeshaw123
id be interested in this, how much weight do they save do u reckon?
Danny Lee
I'd be interested for rears and front sides, all except windscreen.
Cost pending.
Tav
QUOTE(bigstu @ Friday 25th July 2008 - 9:23pm) *
Jah, any ideas on price?
G40rob
Yeah I'm interested. Full set excluding windscreen!
Danny Lee
I'm also very interested in the actual weight which is lost!
Jackblack
any chance of doing squareback rears & tailgate glass? be well up for those and front door repalcements.
bigstu
just emailed paul re: the questions above. will update asap.
Stu
vwmk3jon
this sounds good but I'm just a tad concerned about the security aspect of it all. What's flexyglass like for overall strength?
polopete
interested in the rear and 2 rear sides, but for a mk2 coupe? this possible.
Jackblack
QUOTE(vwmk3jon @ Sunday 31st August 2008 - 10:12pm) *
glass is easier to break than plastic...
Tav
I posted a thread on a local track day asking if anyone had used P4P...got a PM asking about AE86 windows..if they do them + would additional orders for another type of window be beneficial to reducing costs for a Polo group buy?
bigstu
Ok, so have had a mail back from paul, The group buy will be specifically for mk2 and mk3 polo's, all windows excluding the front windscreen, with options for either 1 piece or 2 piece front windows. with out vents these will be £170+vat but that is before any discount and Paul need a minimum 5 orders, but will get bigger discount for 10 orders.
With regards to other models, i wont be doing these on the group buy as i want to keep this as simple as possible, but paul is looking at setting a discount code on the webshop, but this will need more details workin out first.
As such i am now opening the list as will be looking to order asap, so get your names down for a full kit i will confirm total prices with paul once a have a few numbers to work with
1.) Bigstu mk3
2.)
3.)
4.)
5.)
6.)
7.)
8.)
9.)
10.)
Edit for the Q about weight, Paul recons they weigh about 50%of standard glass saving 10-15kgs depending on application, earlier vw have heavier glass
Jackblack
whats the damage for some mk3 door replacements with vents? also what secuity is available on the vents? cheers.
bigstu
Vents are +£25 for drivers side and +£45 for both sides, i believe these are opperated from the inside so guess they are pretty secure
quiksilver_jake
would be interested to see some pics of rear window fitted as bit unsure how it will look so ill prob be on round 2 of group buy wink.gif
Tav
1.) Bigstu mk3
2.)Tav
3.)
4.)
5.)
6.)
7.)
8.)
9.)
10.)
2 Piece from would be the 1/4 window + the main section? I guess I could add my own vents are a later date if I wanted as well?
bigstu
QUOTE(Tav @ Tuesday 2nd September 2008 - 10:43pm) *
yeah thats right Tav, i guess you could add vents later, shouldn't think it would be too difficult. i need to check how the front ones fit to see if the 2 piece ones can be fitted and opperated the same as standard, i.e. would down
Tav
Would also like to know about retaining original rubber seals...especially on the rear side windows and general info. about fitting.
Rear window seals (run a long the bottom of the window on the tail gate, 6mm wide) are obsolete from VW. Sure they'll be easy to replace though.
Jackblack
how much just for 1pc front windows? wont need a kit as i'm square!
also, how are they fitted? was gonna make some myself and just bond them in place, do these need to be in the original seals?
pics would be a massive help.
jez1272gt
I would like to express certain interest in these flexi glass windows. I would be after a full set.
1.) Bigstu mk3
2.)Tav
3.) Jez1272gt
4.)
5.)
6.)
7.)
8.)
9.)
10.)
dubloke
i know for a fact that the 2 piece windows wont wind down due to the design, this is the reason u have the window sliders fitted, for ventilation and to converse with anyone outside the car without having to open the door each time. not sure on the one piece but i imagine its the same and i'd imagine it would scratch quite easily winding it up and down after a while.
g40dabbsy
i would like to no how mutch waight you would save per window or 3peace set also do you make the 2 side massie windows on the breadvan ? wb
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2009 Invision Power Services, Inc.
