kamikazi929
Sunday 25th December 2005 - 8:45pm
Hi everyone this is my first post so go easy on me lol. i seen this post and it catched my eye :
http://www.clubpolo.co.uk/forum/viewtopic.php?t=495
Interested in getting my chip mapped. What does it involve exactly? I understand I will have to removed the chip and send it to you guys, but where is it?
I'm a bit of a newbie when it comes to engine modifying but want to learn. How do i remove the chip? How do i get the codes required? How much does it cost and what sort of BHP increase am i likely to see?
If it helps I'm running 17" wheels , i will try get a picture up of my car soon.
poloace
Sunday 1st January 2006 - 3:28pm
I will need you to post me your ECU, I will then un-solder your original eprom (chip) and fit a socket and the new eprom with the modified code which will give you an increase in power and drivability.
You will need a 10mm socket to remove the ECU it is located underneath the black plastic scuttle panel just below the windscreen on the passenger side. When you remove the cover you should be able to get the numbers from it then.
I will then confirm if I can do the ECu on a same day service if you visit me or if I will need it for 2-3days while I get new code for your ECU.
Price for the MK4 is only £120 inc fitting. any postal cost are extra.
With 17" you willneed all the extra power you can get as they will reduce your acceleration.
kamikazi929
Sunday 1st January 2006 - 4:48pm
excellent i should be able to get the cash together in the next week or so. when i send you the ecu and you send it back? is it just a case of simply "plugging" it back in or is there any work involved?
poloace
Sunday 1st January 2006 - 5:46pm
I will need your ECu for 2-3days. While I have it you will not be able to use your car. once I send it back it will be a matter of plugging it straight in. I will need a week notice before you send it as some of my equipment is on loan.
kamikazi929
Sunday 1st January 2006 - 7:35pm
ok ill let u know asap, is there any other ways of contacting you?
poloace
Sunday 1st January 2006 - 9:57pm
email me direct at poloace@aol.com
jamegumb
Sunday 5th April 2009 - 12:15am
I was wondering if I could get my 1998 1.6 6n 8v ecu mapped. My engine code is AHS. I live in New Zealand where heaps of this engine code polo are imported from Japan. I have resent this message as I wasnt sure if you recieved my first one. Thanks
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please
click here.
