Hi Alan,
I'm not sure if you can help me at all. I have a client with a 16v conversion that i've fitted and the damn thing won't start, vag com is telling me its the immobilisor.
I've fitted everything from the donor vehicle and still no start. I do know its an immobilisor problem because the car is an R reg and uses the older 6 pin transponder box instead of the later spec 8 pin. So i used the ecu, transponder,reciever and key from a P reg and it started and ran...
I may have to get this ecu re-coded, but can you bypass the immobilisor? I've spoken to vw and they require the vehicle to plug into their system to get a link direct to germany for the pass code, which i think is crap...but i just need someone to wipe the chip, re-program it to have no immobilisor and i can send you one asap if i dont manage to find an older ecu/transponder setup to use.
If you could pm me your number, it might be easier to explain over the phone...unless your going to edition38, in which case i'm only round the corner and am attending anyway.
Thanks! Sanj.
