Help - Search - Members - Calendar
Full Version: CHip Prices
Club Polo Forum > Sponsored Forums > Fahrvergnugen Tuning
poloace
All MK3 91-94 £30 +£1 P&P
£10 extra for raised GT limiter
MK4, 1.4 16v, 1.6, 1.4, £120
including removing original chip installing socket and new chip
Gains around 5-10% better acceleration and throttle response, and reduction in flat spots.
I can supply chips for most european cars. Just ask
GTfan
Hi Alan
I've just noticed that you sais you can stock chips for most european cars so would you be able to do one for my brother nova SRI????
cheers
Iain
poloace
Yes I can, can you get me the ECU codes, then I will need the ECu for up to 3 days while I sort the code out.
GTfan
yep sure Alan no problem just gota wait untill he gets in from work!
+ i had a chip of you if you can remember for my GT with the 7300RPM limiter and 4days later i blew my headgasket lol dont worry it was my fault no water in my car, anyway while the head was off i had it ported/polished and gaslflowed and the valve seats cut and oh my god what a differnece the chip reaqlly work well with the flowed head cool.gif
oh just thought where can i find the ECU codes will they be on the ECU???
poloace
Sounds like you have been having fun, soprry to here about the Head gasket. My G40 had a water way corrode though to No 1 cylinder casuing water lose.
If you can get me all the numbers that are on the sticker on the ECu then I can see what version it is a what type of eprom it uses.
GTfan
Rite Alan we found the ECU lol it was behind the glovebox confused.gif anyway here is the code on the sticker which was on the ECU
866149s200695813
then we took the cover of the euu and there was a sticker on the chip which said
DELCO
AWMS
0648
then there were a load of numbers on the chip too
014
89338*
AA9224B
hope this is enough info Alan were jst going to get another ecu while you have the other one! Also could you give me a rough price on how much it is going to cost or will it be the same as mine???
cheers
Iain
GTfan
BUMP????
poloace
I tried to look up the ECU code and have not made an exact match to the listings I have, this is not a major problem but I will need the ECU for a couple of days to read the original code from the original chip. I think the ECU will require a socket and I will be able to do this when I have the ECU.
Was that all the details from the outside of the ECU. Can you confirm the engine cc and valves IU assume its 1.6 8v but I not up on vauxhall cars.
Price wise I thnk will probably be £60, will be more if it turns out to have a surface mounted Eprom.
GTfan
it's a 1.4 8v SRI were in the process of getting another ECU which we can bang in while we send the orginal of to you!The ecu number was on the outside of the casing and the rest of the numbers were either on the chip or a sticker on the chip!
craigellis05
Alriite m8 after chip for my gt will it increase performance alot ? is ther a big difference in the two chips
how long postage and that ?
thanks craigellis05
kerrly
GT chip provides 5-6bhp gain and better throttle responce.
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2012 Invision Power Services, Inc.
