Help - Search - Members - Calendar
Full Version: DIY Mk2/3 rear exhaust hanger replacement guide.
Club Polo Forum > Technical Forums > Engine, Transmission and Exhaust > FAQ
genesisGT
Few people expressed interest when i posted about how to repair the usual mk3 fault of the snapped rear hanger, there are a few solutions but here is mine. it takes about 2 hrs all in and a tea break lol.gif
Parts needed
VW repair panel - 867 803 785 and its only £8.81 + vat (£10.35)
2x 8mm x75 length bolts or similar £2max ( you can go 10mm but i means drilling out more material)
middle rear bump stop rubber optional (i missed it out as it does feck all but you can fit it if you like).
2 new back box exhaust rubbers £2max
4x 8mm penny washers £1max
Tools Needed
a hack saw
electric drill + drill bits small, medium then a 8mm (or 10 to match the bolts you bought)
angle grinder (quickest way to get the old hooks off)
heat gun or hairdryer to melt the underseal.
bit of wood to fit in the middle of the hanger to drill it so it doesnt bend
a large file and a wee circle file (not essential but saves cutting your fingers or mr MOT mans).
old broken hanger on my loon sad.gif did ok for 18 years - good old VW - but i have heard of them braking long before this and then the cable tie army take over usually.
new bits: vw panel, rear exhaust, 2 "O" rings and mid box one and a few long bolts (only need 2 of them)
so i got about changing the vw panel as i dont do welding, and prefer uber minimum drilling holes in things.
panel before on left and as modified on right.
then i grinded off the remaining leg on the car and heat gunned all the underseal on the sides of the original panel, but not on the floor so it remains sealed or you will just open it up to water attack, and then drilled holes through it so it looks like this: (file the edges till they are smooth)
then its a case of drill the VW panel to match and file the holes
then its a nice push up and bolt through operation (may require some hammer time action! nod.gif ).
I chose to double nut it so its locked and cant go anywhere or vibrate loose paranoid.gif :
then i put the "O" rubbers in a old tea pot with water and boiled them for about 5 min so they were lovely and soft. then they slide on nicely. and jobs a good un! cool.gif
then just go give it a blast to make sure its not going anywhere and relax for another 18 years!
only thing i might do extra is give it a coat of paint and underseal round the panel for a proper job. thumbsup.gif
neil_dubgt
thats great dude
genesisGT
it was the best solution i could come up with without breaking all the underseal or drilling and welding half the boot floor.
i got 2 repair panels as my hecks hanger felt fragile last time i looked at it! sad.gif
feel free to move it to FAQ! i must have posted it in the wrong bit! I'm bad for that sometimes lol redface.gif
MacColl
This is fantastic, change your name to geniusGT.
Welding around an area that has so much underseal and sh*t everywhere is a nightmare so thanks for this.
I'm thinking I might want to get my exhaust sitting higher but I suppose it's a case of modding the back box off the car first. I'll wait and see where I end up when I improve my standard 1272cc system..
Cheers.
Olli2004
Thats is genius!
I welded my exhaust as a temporary repair this weekend and noticed mine was looking fragile. At least I arnt going to struggle now!!
genesisGT
its a quick guide to something that will effect most of us mk2/3 people at some point unfortunately! and when it goes their are few options to keep you going in the mean time ( i used a bit of gate chain with a bolt through it.
Oilli i would buy the panel and get making, mine looked solid when i bought the car a few months ago but 3 bad speed bumps and it died.
Maccoll - if u have an aftermarket one which is heaver you could make a wee "U" shape with 2 stronger hooks and bolt it on in the same way made out of some 1 or 3mm steel.
I'm after a aftermarket system so if if this fails or cant take the weight it can be modified -
similarly if you want it to sit higher you could cut more off the top of the VW panel so the Legs on the U are shorter and grind more of the bottom bit on the car so its a "I I" shape than a "U" think that would work. just watch the petrol tank is the other side of the axle when your grinding! so make sure the grind sparks head towards to the back of the car as lots of mk3s have the dreaded fuel tank leak paranoid.gif
MartinB
very nice Richard...
My heck's were like that when i bought it so my brother welded the hanger back on. if i had known they did replacement hangers i would have opted for one of them. my backbox is solidly held at the moment but if it decides to break i'll definitely get one of them panels!
hayesey
I'd give it a good coat of anti-rust paint and/or underseal though or it'll go rusty quite quickly. Nice guide though!
steveeeee
I've been rocking a jumbo zip tie since May and this solution exactly matches my technical skill level. Thanks!
hardhitter01uk
Good guide !
Definately worth using the exhaust bump stop rubber as it stops the exhaust bouncing about so much and banging up into the bumper and wearing the hanger rubbers.
A few things to help people. Get some acid etch primer on the bare metal they expose and you can buy VAG underseal at a not unreasonable price. You need an underseal gun, but it gives a more genuine repair and it would give the same texture. If you were to weld it (which I would) you can get zinc weld through primer for the panel edges you won't be able to paint when it's done.
steveeeee
Just got back from picking up the repair panel plus some oil change gubbins and saw this post. Hmm...
genesisGT
^^^^^that would work just as well, its probubally bit simpler but should be as strong (hanger wise stonger). Alignment will be tiny bit different, as the holes are in the middle of the "U" not the edge but the rubbers if heated will manage that fine.
its a OEM or aftermarket choice, both work and will do the job.
steveeeee
QUOTE (genesisGT @ Thursday 20th November 2008 - 12:28pm) *
Indeed. They're not quite ready with their design yet, and I've already got the proper repair panel so I'm going with your version. I don't have an angle grinder though so I'll be cutting bits off with my trusty herring hacksaw smile.gif
Wiggy
Woo, just ordered me one from VW...should be here tomorrow I never knew parts such as these existed! Lol, thanks!
genesisGT
in the guide i said dont worry about the middle exhaust rubber on the back box! redface.gif
well all this week i have been getting a headache from theexhaust tail pipe bouncing and hitting the bumper so i would recommend fitting it!!! thumbsup.gif
on the plus side the repair is still like new 5 month on
my heck didnt suffer from the bounce issue so maybe its the loons extra length?!
takot
I'm going to be buying this repair panel very soon, my mk3 is crying out for it... just wondered did you order it from GSF as i cant seem to find the part online..?
steveeeee
I got mine from my local independent VAG specialist.
takot
ok. thanks very much
MrClifford
woo nice guide which i was on this forum b4 i got my polo, ended up just gettin my mate to weld a hook onto the backbox, hook onto a bolt, bolt through the boot and a rubber o to hitch um together. still havin a problem with the mid section hangin lowwww tho!
bort
i think this post highlights the importance of people doing a job properly and the people bending bolts and sticking them on with pigeon shit dont forget things like this when buying a polo
matt646
ordered my part today, but it was £9.69 + vat = £11.14! good FAQ though
genesisGT
QUOTE (matt646 @ Monday 24th August 2009 - 6:36pm) *
lol.gif well it is nearly a year on! recon that panel will be obsolite in the next year or two the rate its selling.
Oaten
I just ordered this part from VW costing me £10 should be here friday I can finally get rid of that welding rod that is supporting me exhaust
aroncmc22
Just ordered one too, dont really need it at the mo but I dare say I will in the not to distant future..
Only 1 left at the factory now
Excellent guide btw
danthepoloman
it is now obsolite not just got off the phone with sinclair n there is one in the uk surprised.gif
DTSpolo
I've looked everywhere for one of these? do they still sell them or does anyone have one anywhere they are will to sell? cheers.
runforrestrun
go to the VAG dealer. part number is 867803785
adamburton93
Think you'll find these are now obsolete, time to put your thinking cap on and design something yourself
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2012 Invision Power Services, Inc.
