Sentral
Saturday 16th July 2005 - 9:48pm
When your car is serviced at a non-vw garage or at home by yourslef, the ecu doesnt know its had a service, so the service indicator stays on. To reset it:
-(with the ignition off and keys out) press and hold the mile reset button
-turn ignition on
-wait until the display goes like '--'
-turn ignition off and keys out and release button
viola
meathead
Monday 18th July 2005 - 4:13pm
cheers m8 that was much help that service light was frustrating me
mr-rumble
Thursday 13th October 2005 - 12:53pm
Doesn't seem to work on mine....
Kaws
Sunday 16th October 2005 - 11:43am
My hanes says 98< polo's can only be reset by vw (or somebody with the right kit) Doing the button combo won't work. Annoying huh
Saxyhelen
Wednesday 26th October 2005 - 6:11pm
Polo 96-99
IN01 -inspection service
Switch ignition ON
Press and hold button (A left) under speedo
Switch ignition OFF
Release button
Press and release button A (left)
The letter "IN01" will appear in the odometer display of the speedometer.
Press clock minute button B until "-----" appears in the display
Press button A (left) to display "OEL"
Press button B to display "-----"
Switch ignition on until the letters "IN00" appear in the display
I have instructions for Oil service (OEL) and IN02 inspection service if this doesn't work.
raffa
Saturday 19th November 2005 - 3:07pm
that is till models 98, 98 - 99 have to be done thru the ecu. like mine.
Dubby
Monday 21st November 2005 - 10:12am
QUOTE (Indigo)
-turn ignition on
viola :)
So would this method work on a 2000 polo gti??
Christian6N
Tuesday 10th January 2006 - 10:22pm
QUOTE (raffa)
No, on all mk4 u can DIY, on another buttoncombination.... take this german text from my homepage and translate it, the mk5 service display needs it to vag com, not the mk4.
http://www.vwpolo6n.de/de/tipsundtricks/an...rviceneueze.htm
Christian
TomVW
Tuesday 11th April 2006 - 12:18pm
QUOTE (Saxyhelen)
I have got to here and cant do the next bit?
QUOTE (Saxyhelen)
where am I going wrong?
I try and switch the indicator on and it just goes back to normal IN01?
psibob84
Thursday 27th April 2006 - 5:29pm
This is from the haynes manual for my 95 mk4 polo.
i have done this and it works.
QUOTE
Up to 1998 model year
1 Before resetting the service interval display, make sure the mileometer is displaying the total mileage, and is not in trip mode. Briefly pressing the button to the left of the speedometer will switch the display between total and trip. Note: If the button is pressed and held for longer then one second while in trip mode, the trip meter will be zeroed.
2 Switch on the ignition (do not start the engine). Press and hold the button to the left of the speedometer.
3 Switch off the igniton, then release the button. The display should now read OEL.
4 Now press the digital clock lower button on the right-hand side of the instrument panel until five dashes appear on the display. The OEL service is now reset.
5 By pressing the left-hand button again, the next service interval can be displayed, and then reset by pressing the right-hand button.
6 Reset as many services as necessary, until switching on the ignition only shows IN 00 (no service required) on the display.
thats enough typing for me for today
Nick_16v
Monday 22nd May 2006 - 4:16pm
K i have a 1999 polo 6n 16v and i can't for the life of me get the oil service thing to reset, i reset it when it was just a service light sometime ago but i can't remeber how, any ideas?
Nick_16v
Monday 22nd May 2006 - 4:25pm
done just have to hold the button for at least 10 seconds
1. reset odometer
2. press and hold button
3. switch on ignition
4. hold until --- is displayed
5. voila
PHILIP1193
Monday 22nd May 2006 - 9:09pm
how is this done on mark 5 polo's or isn;t it?
Phil
GiorgioGT
Wednesday 24th May 2006 - 5:32pm
Mk5 needs the VAG COM. Go to a good garage and ask if they will turn it off.
mrsibs
Wednesday 13th September 2006 - 9:51pm
ok maybe i gotta hold it for longer
6Newan
Sunday 17th September 2006 - 5:33pm
It also tells you how to do it in the Owner's Manual!
redbellyben
Sunday 11th March 2007 - 4:41pm
QUOTE
whats the instructions for (oel) and in02? I've got in02 up on mine
part time hero
Monday 13th August 2007 - 12:34pm
QUOTE (Nick_16v @ Monday 22nd May 2006 - 5:25pm)
1. reset odometer
5. voila
this worked first time on my R reg 16v cheers
mbuckley91
Friday 19th October 2007 - 3:00pm
fantastic this solution worked on my polo 1.0l 98
great stuff
Leeno
Thursday 13th December 2007 - 12:07pm
I've just brought a x Reg 2000 Polo Estate E TDI.
My dashboard Display just says 'Service Miles' Then the amount of miles rising.
Anyway to get rid of this?
nykie
Saturday 15th March 2008 - 10:15am
just done it on my 16v, seemed to work!
squarebackmatt
Monday 31st March 2008 - 6:42pm
just done it and it worked thanks
Confused soul
Tuesday 8th July 2008 - 7:03am
Does anybody know how to reset the service indicator on Polo 1.2 2003?
Tom9n
Sunday 13th July 2008 - 4:19pm
Yeah I'd like to know that also, mine will come on in a few hundred miles
polo6n_1
Sunday 13th July 2008 - 6:04pm
my ones been on for about 700miles, but I'm thinkin 2 service my car so the garage will probably take it off them selves...
also how often does the inspection light come on? does it work mileage wise or when your car actualy needs service, e.g. changing oils n others.
also how much is a fairly decent price for a full service?
cheers
EX-DOHCTOR
Monday 21st July 2008 - 10:19am
I have a 2004 1.4i Polo (9N) and my oil service light just came on now (like 1500KM's after the last service).
Will the above method(s) work on my car?
JohnCoupe
Saturday 20th September 2008 - 11:11am
Works on my 2000 GTI, got to count to 10 at each stage!
6n-5dr-1600-auto
Tuesday 25th November 2008 - 9:11pm
QUOTE (Saxyhelen @ Wednesday 26th October 2005 - 6:11pm)
Polo 96-99
IN01 -inspection serviceSwitch ignition ON
Switch ignition OFF
Release button
hi sorry to disturb you i followed your guide to resetting the service warning as i just had a full service including cambelt change, the odometer always prompted INO1 now I've got the OEL what should it be set to ? as i was messing around with the same steps after getting the OEL
I was able to bring up the following
OEL
INO1.S
IN02.S
it was something along the lines of what I've just put up above, thanks for your help
6n-5dr-1600-auto
Thursday 27th November 2008 - 11:54pm
can anyone please help me as i know get OEL displayed i just want to set to the next appropriate setting so it comes up when the right warning should later on
thanks
pedge
Thursday 11th December 2008 - 1:16pm
QUOTE (part time hero @ Monday 13th August 2007 - 12:34pm)
1. reset odometer
5. voila
alos worked 4 me on my r reg 1.4 8v
silentbob1989
Thursday 11th December 2008 - 10:17pm
'97 1L
With ignition on (Engine Off)
1. Select total Mileage by pressing the right button.
2. Hold right button down.
3. Turn ignition off
4. Wait ten seconds
5. Turn Ignition ON
6. Keep holding until --- is displayed (you will see stuff like 'INS' and 'OIL' then '---')
7. Done!
naaathaaan
Sunday 25th January 2009 - 10:33pm
Okay, I have a 1997 MK4
I had the INSP02 light on
Took a read at the owners manual, It said:
Turn on the ignition - But do not start the engine.
Press and hold the milometer button (the larger one on the left of the cluster)
While holding, Remove the key, You are then faced with the 3 possible indicators,
These are OEL- Oil change needed
INSP01 - Annual Inspection/Service Needed
INSP02 - Annual Inspection/Service AND work needed.
Then to remove the indicator, select, by pressing the milometer button again and hold the minute change button.
This is the lower button next to the clock.
You are then showen "- - - - -"
This confirms the indicator has been wiped.
T-Diddy
Tuesday 10th March 2009 - 2:04am
my service light has been on for weeks and its been getting on my nerves,
I've just tried this one at 1:30am after finding this forum and it works, i had to change it slightly,
i have a
1998 1L POLO
reset the miles button
insert the key and turn it once, just before the ignition
press & hold the miles reset button
turn ignition on whilst button still pressed
wait unitll the display goes ---
turn the ignition off then release the keys
that should sort it,
mk2_coupeS
Sunday 31st May 2009 - 8:43pm
thanks mate it was totally annoying me, mines is a 1999 2 sec job
Alibloke
Saturday 6th February 2010 - 7:15am
Hi guys, hope you can help.
I reset the service indicator on my 05 polo, however it's come back on again after about 15k miles. I've read that this is the standard for the manual reset but I'm on long life oil so it should last much longer than this. If I reset it again manually does this mean that it will simply wait another 15k blindly or will the sensors think the oil is due a change kick in before that? I don't want to keep resetting it if the variable indicator isn't going to work.
muzzamotorsport
Friday 12th February 2010 - 11:19pm
QUOTE (Alibloke @ Saturday 6th February 2010 - 7:15am)
IMO the oil should be changed after no longer than 15k (even on long life oil); the carbon build up will be killing the efficiency of the engine by that point, thus costing mpg. It’s a bit of a false economy. The other main reason for changing the oil more often is to reduce wear of the main moving components, such as big end shell bearings, and the piston rings, because of the build-up of deposits (such as swarf).
I like an oil change at bang on every 5k, that way I know where I’m at, and at MOT time the emitions came back as 8 parts per million hydrocarbons, out of an allowable 200.
Thats just my opinion on the whole oil service thing.
Regards
Neil
Alibloke
Saturday 13th February 2010 - 8:27am
QUOTE (muzzamotorsport @ Friday 12th February 2010 - 11:19pm)
Regards
Neil
Thanks for the info, I'm planning on keeping this car until it dies so I'd like to keep it in good shape. I'll go for an oil change at 15k.
blandy123
Monday 22nd March 2010 - 4:47pm
QUOTE (Nick_16v @ Monday 22nd May 2006 - 4:25pm)
1. reset odometer
5. voila
Great help it was starting to anoy me
rich4130
Thursday 25th March 2010 - 9:35pm
For MK5> change it with Vag-Com, Go into installation list, instruments, and then change one of the adaption channels to a 0 (will be a 1 IIRC) Easy!
Rehatch420
Saturday 9th April 2011 - 3:10pm
this worked on my 2000 gti, will keep you posted if the light comes back on any time soon
cheers
rich
klb18
Wednesday 11th May 2011 - 10:41am
QUOTE (Indigo @ Saturday 16th July 2005 - 10:48pm)
-turn ignition on
viola
Big help cheers
muckup87
Monday 12th March 2012 - 10:42pm
I've got a 99 1.4 16v, and I cant reset mine. I have found the trip reset also doesnt work. Is this the only way to reset it? and does anyone know if its a cheap fix for the buton if not
Callum soutar
Wednesday 14th March 2012 - 5:01pm
Just cleared my IN02, worked like a treat
cheers for this
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please
click here.
