Help - Search - Members - Calendar
Full Version: Poly engine mounts
Club Polo Forum > Sponsored Forums > Jackson Tuning > Mk 1/2/3
PhilJ
Batch has arrived, so if anyone is after them, give me a shout.
Easy enough to fit, will need a press to get them in, and you re use the metal insert from your old bushes. They are just the rubbers. Similar to the groupbuy mounts that have been ran previously except I have had these made in .65 shore rating rather than the .50/.55 so they are a bit stiffer than previous lots and should stop any unwanted engine movement well. They are coming in at £35 each mount, or I will do a full set of 3 for £95 delivered.
Give me a PM if you are interested in ordering.
Narrow_Lane
Is that 35 posted? Put me down for one please.
Also if I'm going for just one these, which mount is the best place to put it? Top gearbox mount?
stumpymk2coupe
Lower gearbox will stop your rocking
Mk1_Golf_Chriz
Id be interested. Easy enough to replace the rubbers?
Oily Fingers
i'd be interested in a set, go well with the eaton build
dekerf1996
I have got a set of Phil's prototypes on my G40, and they have transformed the car really.
At first i just stuck the rear one on, and it made a great improvement, reduced the engine movement no end. Before i had a little exhaust knocking under load, this was gone smile.gif
Fitted the other two and they have helped to control things much better now.
I had a set of the original ones on my GT and yes they were better than standard, but still way too soft. With midly tuned GT there was still a lot of movement. Now with a midly tuned G40 engine there is a lot less movement, dispite there being around 45% more power smile.gif
All in all, i would highly recommend them. I am going to be getting another set for my high powered G40 that i am building (well around 170 bhp)
PhilJ
Glad they sorted the motor out Mark, I think the original batch were softer than the .55 rating thinking about it, either way sounds like they've done the trick. Have you noticed any extra vibrations or disadvantages to them?
Oily Fingers
kool i'll be wanting a set of 3. I'll pm when i get paid later in the week!!!!!
PhilJ
Anyone interested just give me a PM when you are ready.
dekerf1996
Phil, put us down for a set please, will paypal you? Drop me a email if any different or you need any more info?
StinkyPete
thanks phil mine arrived last week il get it put in when i receive my s2 subframe from ppp.
PhilJ
thumbsup.gif Let us know you get on.
flatg40
are there more vibrations from the engine with these mounts ?
randombadger69
QUOTE (PhilJ @ Friday 23rd September 2011 - 8:02pm) *
Good stuff phil, may need another set of engine mounts soon, i'll let you know.
As for fitting i got the ones off the group buy in with a polo sus turret top-cap, lube, two bits of wood and a vice (sounds kinky!).
Sounds a bit of a pikey method, but it's not what you've got, it's what you do with it wink.gif
PhilJ
lol.gif Fair enough, if its works without damaging the bush then its all good.
PhilJ
Engine mounts back in stock. Now black in colour and a touch stiffer.
Everyone's on back order should be with them within a couple of days.
mk2Manic
Borednow
Arrived today cheers Phil. Just got to get em fitted.
Cheers.
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2012 Invision Power Services, Inc.
