Jump to content
kiran_182
information - mk2f GT tuning
Recommended Posts
kiran_182
some info on improving your mk2f  GT, not a comprehensive post so feel free to add you tips
these are the quick power gains
• high lift cam 264 / 268 / 270 - the biggest gain is made here. dont forget new tappets
• 4 branch manifold and exhaust system - dont go to large or it will cost you power
• bigger injectors
• better air filter
• chipped ecu
those probably account for 95% of the gain you can get from the engine
the next lot help to pull a few extra horses out for those who really want to put the work in:
• skimmed head / port matched with inlet / exhaust
• de-wedged ported throttle body
• lightened flywheel - not really power but will spin the engine up faster. be warned if the fly is to light the crank will wear its bearings
in opposition to porting the inlet you can use a NZ/G40 inlet with smaller holes to fill in the gap created by the highlift cam moving the powerband higher
above all refresh the electric and cooling systems to have a solid runner
  • Like 1
Share this post
Link to post
Share on other sites
kwijibo_coupe
If you know how to set them up than a Mk2 Golf AFM can give a decent boost in power. They are less restrictive anyway so could be a good addition if you have other mods on the inlet side.
Personally I think the best thing about the GT is the GT gearbox. The short ratios really make the most of the lack of torque and help keep the revs in the power band.
Share this post
Link to post
kiran_182
On 12/02/2017 at 22:02, bradstub said:
Do you know what injectors would be best?
With a 270 cam i ran 200cc g40s and have now got 249cc injectors
To add my experience since posting. My setup is:
• newman 270 cam std pulley
• 249cc injectors
• g40 inlet
• 8k chipped ecu
• 421 with jettex g40 system
The big difference is how you set the timing, ignition timing, mix and idle
The exact same setup can be slow or fast depending on those factors
  • Like 1
Share this post
Link to post
BIG RHYS
Hey can anyone help.
I can't find a cam for the Polo GT.
Looking at getting a newman 270/270 cam for the Polo GT.
The ones on ebay are listed for the Polo G40. Will this also fit the polo GT?
Share this post
Link to post
steveo3002
no dont buy a g40 cam...you can ring newman and ask for the 268/268 although ive seen one latley and it looked terrible quality
id pay the extra for a schrick if you can manage
  • Like 1
Share this post
Link to post
BIG RHYS
Thanks pal for the fast response.
I''ll take a look at schrick for 👍
Share this post
Link to post
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
  • Create New...
