Jump to content
heyholly__
Mk2 Coupe Fuel Tank Removal
Recommended Posts
heyholly__
Hi all,
Has anyone ever removed the fuel tank from a Mk2 Coupe? Mine has a leak so was just wondering how easy (or difficult!) it is.
Any help would be appreciated :)
Thanks!
Share this post
Link to post
Share on other sites
Yeti
Get the back end of the car up as far as possible and it's a pain in the arse, but certainly doable. Some people loosen or drop the offside rear axle mount.
Pattern tanks often have the fuel filler neck a bit out of shape, about the only way I've found to adjust it is to slide a broom handle down and pull it into line.
Tanks on 82-84 cars are smaller, and hard to find.
  • Like 1
Share this post
Link to post
westy02
Remove drivers rear wheel to get the neck in and out
  • Like 1
Share this post
Link to post
heyholly__
Cheers! I have access to a ramp which should hopefully make this all a bit easier.
Any idea which bolts need to be removed? We've tried before by taking the tank strap off but couldn't seem to move it more than a few inches which is less than ideal when we want to completely remove it...
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
  • Create New...
