Jump to content
Sign in to follow this
damunk
G40, MK2 POLO OIL SUMP
Recommended Posts
damunk
Can someone please confirm the G40 oil sump gasket is the same as the MK2f 1991 polo because I am using a shallow sump from the MK2 on the 6N which fits.
I have seen baffle plates available for the G40 1.3 1986 - 1994 where the fitting looks identical  to the sump I am using now for the 6N.
Please see picture.
Share this post
Link to post
Share on other sites
steveo3002
yes g40 = same as mk2 and mk2f
Share this post
Link to post
damunk
I don't know why they don't show them as compatible gaskets on ebay because if you look closely at the pic I posted, at the bottom right there is a hole for the screw that is wider than the others.
this bigger hole allows the screw to fit into the AFH block.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
  • Create New...
