Jump to content
Cliff81
Misfire only at idle after few minutes.
Recommended Posts
Cliff81
Hi Everyone, new to the forum, I have a Passat 1.8T wagon but stumped with the issue on the wife’s Polo 1.4 16v BBY 89k, car drives fine mrs can drive it to work and home 4mile round trip and it’s fine, if stopped in traffic or left idleing for a few minutes when warm the EPC starts flashing, car starts to misfire on Number 4 16688, if turned off and restarted the misfire and epc disappears and all is fine, I have tried new coils and plugs and swapped them round, no signs of head gasket failure and no smoke at all. No vac leaks, no other fault codes, I also unplugged the egr and made no difference, TB is spotless, possible injector, Valves, EGR, CTS? Just want to see if anyone has had the same before I take to our local Indy for compression/fault testing. Thanks
Share this post
Link to post
Share on other sites
vwfan3
23 minutes ago, Cliff81 said:
...... I have tried new coils and plugs and swapped them round. Just want to see if anyone has had the same before I take to our local Indy for compression/fault testing. Thanks
Hi
You have made no mention of the ignition leads. That would be my next port of call.
Share this post
Link to post
nige8021
First Welcome to the forum.
Get a compression test done, had the same problem on another members car a few years ago.
7 minutes ago, vwfan3 said:
Hi
It is coil on plug engine so no ignition leads !!
  • Like 1
Share this post
Link to post
vwfan3
Hi
In that case, would it be a good idea to check/clean the contacts and the cable near the connector to coil no 4.
  • Like 1
Share this post
Link to post
Cliff81
Thanks, looks like a trip to the local Indy for testing probably best to rule out compression before throwing money at it, if it is valves woudnt the misfire be there constant?
Share this post
Link to post
nige8021
Your symptoms are the same as a previous members and at the time it didn't make sense, but after doing the same things you have already tried, plus cleaning the throttle body & doing the throttle body alignment and cleaning the MAP/IAT sensor on the cambelt end of the inlet manifold none of those made any difference it was only as a last resort he got a wet & dry compression test done and I think it was the #3 was well down on compression
Share this post
Link to post
Cliff81
Dropped car off for compression testing this morning will await the results, I noticed it has used a lot of fuel in very few miles tho... car does hit 90deg temp hopefully just injector.
Share this post
Link to post
Cliff81
Update!
Cylinder 4 140psi cylinders 1-3 220psi, they done two different test to prove it.
I have been quoted £400-500 to do all valves and get the motor running. Looking at used engines I’m looking at £250ish plus £200 fitting with the risk of it he same problem, so Looks like the strip down option is more viable.
Unless someone has a decent rebuilt head going?
Share this post
Link to post
nige8021
Well at least you know what the problem is, but that does seem a bit steep for the head repair, I had an 8v head skimmed & 4 valves done 18 months ago and that was only £80+vat
Share this post
Link to post
Cliff81
Bit of a gutter yes, the price quoted was for full head refurb crack/pressure treated & skim including all gaskets cambelt/water pump & service etc. I thought the price was reasonable?
Stevens VW have a BBY in stock £300 delivered 3 months warranty, but what do they mean by fully tested? Is that compression tested?
Thanks.
Share this post
Link to post
nige8021
OK if that's the complete job, I don't suppose it is too bad, I thought that was for just refurbing the required valves, I think I would go with that option rather than risk an unknown engine, Ok it might have 3 months warranty but that won't include any labour charges for pulling it out again.
Stevens are a reputable company, I've had many smaller spares from them without any problems, but not sure I would risk an engine without seeing it running and having it compression tested ?
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
  • Create New...
