Jump to content
Sign in to follow this
damunk
N90279001 hexagon collar nut
Recommended Posts
damunk
Any one know where I can get 22 of these:
N  90279001
hexagon collar nut
For camshaft bearing caps.
There are like £4 each on ebay = ouch
Unless I just use a nut and a washer?
Edited by damunk
Share this post
Link to post
Share on other sites
damunk
Some one can confirm pitch size N10045301 is same as N90279001
Both are M7. look good. have ordered 22 from that heritage site but they will confirm postage soon.
Share this post
Link to post
kiran_182
Cant imagine vw changed for a different nut when they had one theyd been using for years but you never know
The 6n originally had an AAV engine at launch as its own wasnt ready so i imagine they used all existing nuts and bolts on the new casttings
Hopefully its what you need and may help some other people out too
Share this post
Link to post
damunk
i looked at the pic , looks the same. if it is m7 then the pitch must be the same for that size of nut.
Share this post
Link to post
damunk
little bit of a twist on the N10045301
A eBay suppler messages back with:
the replacement of N90279001 the part you are looking for, is the N 90279006
and not this.
we have 25 of N 90279006 it in stock and shipping/handling would be 7.95gbp
Share this post
Link to post
Yeti
https://volkswagen.7zap.com/en/rdw/polo+derby+vento-ind/po/1996-158/1/103-103035/ item 13?
Assuming it's AFH. This page lists it as m7. So long as the washer is small enough to sit flat on the journal, you should be ok with a standard nut and a plain washer, although m7 is a bit of an odd size to find. The main difference is normally that the ones VAG used are a bit soft, so that they get damaged threads rather than stripping the stud in the head.
Share this post
Link to post
damunk
I thought about a washer and a nut but though safe way was to use a flanged nut.
Share this post
Link to post
Yeti
That sounds a better option
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
  • Create New...
