Jump to content
kainy
Polo 6N2 Engine Swap AUA to AHW
Recommended Posts
kainy
Hi,
The two Polos in question are:
1. 6N2 2000 1.4 75hp AHW engine, cable throttle - okay working, probably a bit under-powered, will check cylinder compression
- normal AC
- 2 doors
2. 6N2 2000 1.4 75hp AUA engine, wired throttle - engine is bust - overheated because of oil pump failure.
- climatronic
- 4 doors
I'm still considering other options, but the best at the moment seems to be to combine the two into 1 fully working Polo, with the 4 doors Polo as the base.
The main question is: "Is the engine swap plug and play?" - this concerns only the engine unit, with everything immediately attached - water pump, pulleys, alternator. This is to put the AHW engine instead of the AUA. Should I swap it with the gearbox or there is no need?
Share this post
Link to post
Share on other sites
Create an account
Register a new account
Sign in
Sign In Now
  • Create New...
