Jump to content
mattpolog40
Misfire on cylinder number 2 polo g40
Recommended Posts
mattpolog40
Been having trouble with my 40 for a few months now which all started with the distributor filling with oil.since then it’s developed an annoying misfire which I have now worked out is happening in cylinder number 2.im just unsure as to what my next move is if I’m honest I’ve done a compression test it’s not great but not bad either.Any advice would be greatly appreciated
Share this post
Link to post
Share on other sites
kiran_182
Would be the gasket is burning through between 2 cylinders
Share this post
Link to post
kwijibo_coupe
What were the results of the compression test? Was cylinder 2 down by more than 10% between the other 3?
Share this post
Link to post
mattpolog40
8% lower than the other 3 cylinders to be exact on the compression test.i did think it was the head gasket just before Christmas and a few people said not to waste my time and money
Share this post
Link to post
kiran_182
Only a g40  not worth the effort anyway....
Share this post
Link to post
mattpolog40
Mate I’m not far off selling the dam thing it’s to much trouble
Share this post
Link to post
kiran_182
Ill keep £100 in my pocket 24hrs a day just call me and ill get it collected
Share this post
Link to post
kiran_182
But seriously, hg change and a slow rebuild with all nuts bolts and pipes going on firmly and clean can do wonders
Share this post
Link to post
mattpolog40
Awsome I will get one ordered then mate thank you it’s always good to ask for people’s opinions in my eyes
Share this post
Link to post
kwijibo_coupe
A head gasket change on a G40 is no harder than any Polo of the same era. In fact you almost couldn't ask for an easier head gasket job. The only expensive and hard to find part is the head bolts. Apart from them everything else is the same. You'll be £100 or so in parts, a good weekends work and it will be all sorted.
I'd advise getting the head skimmed if you do go down the head gasket route though.
Share this post
Link to post
mattpolog40
I’ve done the head a few times if I’m honest Infact I enjoy doing it I can give everything a good clean and check everything is clean I’ve managed to source all the parts so looks like I’m good to go.
Share this post
Link to post
mattpolog40
Just a quick update cylinders 2 and 3 are at 8 bar and 1 and 3 are just over 11 and a half on the compression test
Share this post
Link to post
kwijibo_coupe
Sounds like the gasket has blown between 2&3 then.
Share this post
Link to post
mattpolog40
That sounds most logical as I say just want input just to check before I strip it all down
Share this post
Link to post
mattpolog40
Turns out the bottom end has gone so I’m in need of a set of pistons a g40 bottom end or a 1w bottom end I’ll take what ever is going if anyone knows of anything going please get in touch thanks
Share this post
Link to post
mattpolog40
That’s not a wanted request that’s me asking people to keep theres ears open for parts for me by the way before someone shoots me down for wanted requests ?
Share this post
Link to post
dvderlm
Is the bottom end so shafted you'll need rebore and oversize pistons, or just hone and new rings?
Share this post
Link to post
mattpolog40
It needs honeing and 2 new pistons but I think I’m going to  struggle to find two piston shoes
Share this post
Link to post
mattpolog40
Don’t know why it put shoes it’s this phone sorry
Share this post
Link to post
dvderlm
030107065AG looks to be part number for G40 piston.
Wonder how they differ from 3F pistons?
Share this post
Link to post
mattpolog40
Nice one mate you are a diamond thank you so much erm I’ve not found much info in difference in variations I must admit I’m struggling abit
Share this post
Link to post
kiran_182
Probably the indent in the top. AAU ones are quite shallow compared to AAV. Could be for the compression ratio
Share this post
Link to post
kiran_182
Got the time and money to stroke the engine?
Share this post
Link to post
mattpolog40
Cylinder head is perfect got it on the bench it all looks very clean and in good working order.
as regards to stroking this is the 3rd bottom end i will be on so this is getting beyond a joke now money wise
Share this post
Link to post
kiran_182
Has the head been rebuilt? Are you over fueling? Killing 3 bottom ends means something is up
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
  • Create New...
