Jump to content
Recommended Posts
Antony Eggleshaw
Hi guys new on here, what is the best carburettor cleaner going?
  • Like 1
Share this post
Link to post
Share on other sites
PHIL SWARBRICK
The Halfords cleaner is OK. Access to a compressor to blow out jets and galleries will help.
  • Like 1
Share this post
Link to post
dvderlm
Never noticed any difference in any of the carb cleaner sprays. All with toluene work well. Never dared use brake cleaner which is more vicious.
Can of compressed air for cleaning keyboards and a length of 3mm diameter silicone tube.
Seafoam dissolves fuel varnish. Dismantle and scrape with wood like a chopstick. Not the tiny holes or jets.
If in a really bad state (ethanol phase separation yellow crud).
An ultrasonic bath and a new set of gaskets.
If water damaged corrosion white crusty powdered aluminium, new carb or fuel injection conversion.
  • Like 1
  • Thanks 1
Share this post
Link to post
Antony Eggleshaw
Thank you will try one of these, do you think somthing like redex would work?
  • Like 1
Share this post
Link to post
dvderlm
As a petrol additive it will help stop carb freezing. As a cleaner sprayed down the air intake or onto top of open carb not so much as a dedicated cleaner spray like STP.
Redex does appear to help injectors on injection and diesel but these force fuel through with high pressure pump, rather than engine sucking.
What are the symptoms?
Air leak at carb base mounting gasket is most common problem, not the carb itself.
Edited by dvderlm
  • Like 1
Share this post
Link to post
dvderlm
or this DIY ultrasonic cleaner (have to remove carbs and disassemble)
http://www.classicbikeforum.co.uk/viewtopic.php?f=27&t=3358
Try not to laugh at the cleaning solution. It bubbles up, which cleans.
Dishwasher tablet/powder to degrease.
Edited by dvderlm
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
  • Create New...
