Jump to content
  2. Jim1500
    Scirocco GTX
    Love this! I'd a Scala injection for 9years and it wrecked me having to part with it, but needed more doors. They're a real natural progression from a Mk2/3 Polo, go like stink, handle well and easy run! Keep the pics coming
  3. Jim1500
    Zastava GT
    Haven't seen one of these in years! They were based on a Fiat 128 or something weren't they? looks awesome on the minilites
  4. Jim1500
    Skoda MK1 Octavia VRS - BLACK
    Lovely car dude, I've a red one for the past 4years almost phenomenol motors! Go like a scalded cat, comfy, huuuuuuuge boot and look well.
  5. Today
  6. lukke
    Polos out of the shed
    You kno. And the thing you want is buried. I find things I forgot I had
  7. Jim1500
    Class! A shed that big would be great, only thing is I say any of us would have it filled within no time lol
  8. Check VW heritage, they list some rubbers for MK2s but I can't remember exactly what they have.
  9. Yesterday
  10. Does anyone the situation with window rubbers all the window are out so. Can you get new fresh rubbers. Or old ones the way
  11. lukke
    So do I. Used to a council garage hahah
  12. lukke
    So.... been a while the car been blasted and striped of all rust n primer old filler Primed ready for a few repairs it unveild bit of welding need front window water hole drip thing ( bottom right hand corner ) And rear window bottom left hand corner
  13. lukke
    It's still there next to the Fridge ...
  14. Without any trumpets inside enlarged Dergo filters and the above custom 31mm chokes I recorded +0.39psi manifold pressure from ram tuning at 13.0:1AFR. Don't think I've seen much over +0.3psi with smooth 30mm chokes and 45mm long trumpets. I found a previous peak +0.34psi at 13.2:1AFR. Think that might have been with 26mm chokes from the log date.
  15. Jim1500
    Mk2 Panels
    Cheers dude, but that's the one I was looking into £50+vat + £36 post over here! They seem to be only place that do it. I'll maybe wait until it's away to get the work done and see what he makes of bodycut I have.
  16. nige8021
    Mk2 Panels
    https://www.carbodypanels4u.co.uk/volkswagen/polo/volkswagen-polo-3-door-hatchback-1981-1990-mk2/battery-tray
  17. It wasn't a nyloc, and looks like it wasn't even a tapered locknut to begin with... Stupid oversight - you live and learn... Yeah I think that description is wrong - would seem strange to use a nyloc when every other nut on the suspension is a tapered locknut. Found two original VW nuts to use either way.
  18. Jim1500
    Mk2 Panels
    Anywhere else do the battery tray repair panels? By the time vat and postage on that it's going to be almost £100!!! I've been searching ebay etc can't find anyone else, even can't find what make the panel is.
  19. Was it a nyloc nut on the ARB end? Please don't reuse those. I can find N0221414 described as nylock at VWheritage. but the 7zap picture looks like it could be tapered thread
  20. Ha! Consider me disappointed! I'll have to get on giving that a lick of paint asap. Either that or just swap for a new sump when I next do the oil (which is pretty soon anyways).
  21. Sorry to disappoint you. Sheet steel at £25 ish. Feld Motorsport sell an alu sump for €240 ish. https://www.feld-motorsport.de/files/CLASSIC-LINE-ANGEBOTSLISTE-PDF.pdf
  22. Torque wrench was reading a tad high - used a digital luggage scale at a measured point on the handle and pulled against the wheel nuts (vice didn't grip the socket head enough. All calibrated now - thanks for the headsup!
  23. Very true - I always try and make sure I have enough space around the wrench when torquing a nut up to hit the click in one smooth movement. When I say the other nut was still at torque I mean it hasn't moved from where I torqued it to. I'll see if I can't set up a test rig to check the wrench - it'll be something to do in the evening if nothing else!
  24. I'm running stock springs (1 coil cut out all round 15-20m low) and stock shocks at the moment on my 84 bready. I like having the travel on the stock springs because my local routes have shite bumps. I just want better damping performance and more progressive shocks for the roll. Has anyone tried these shocks? I would consider getting sportier springs too but its my daily so not that fussed, its already fun right now while feeling chilled to drive, crashy thumps wise. Also just to mention i have a pair of powerflex ARB polly bushings if anyone wants them off me. Cheers
  25. A couple of things about 'checking' the torque of a nut or bolt and torque wrench calibration. The correct torque of a bolt/nut can ONLY be checked whilst it is actually being tightened - It is NOT possible to simply put the torque wrench back on it to 'check' as the initial resistance to turning would prevent an accurate reading - It might even be possible to increase the setting slightly and still get a 'click' out of it without it turning the bolt/nut. A very rough method of checking that your torque wrench is giving something like the correct result is to use a spring balance at a point exactly 12 inches from the centre of the drive square. Set the wrench to a setting in lbs/ft (ft/lbs if you like) , grip the square in the vice and pull on the spring balance - the wrench should 'click' at the appropriate setting. This is NOT a super accurate calibration check, as there are some variables - not least, the accuracy of the spring balance (but you could check that against a known weight). This check is best repeated at two or three settings of the wrench. Regards
  26. CAR INSURANCE DUE SOON? We're offering everyone who gets a car insurance quote from us before the end of July the chance to WIN a £100 Amazon voucher. Enthusiasts currently save 22.9% against their existing renewal on average by switching to Chris Knott so it could be a double win for you. You can use the link below or call us on 0800 917 2274 (please mention this car club or forum to access our special scheme for members and enthusiasts). Full details at https://www.chrisknott.co.uk/rewards/win-p100-amazon-voucher-chris-knott-2019.html best, Nick PS. If your insurance isn't due for a while you could still win with Chris Knott... Enter the Chris Knott #showandshine - https://www.chrisknott.co.uk/news/chris-knott-show-shine-competition-2019.html - and show us what you've got! *** Testimonials Here's some feedback about the Chris Knott service... "Gave me the best quote for my BMW 520d. Best price including comprehensive breakdown cover and legal aid etc included too!" Rob M, TrustPilot "Good service, good solution. No fuss!" Timothy A, TrustPilot "The company has helped tremendously - Milton and Kathy have bean fantastic and help in every way possible." Kevin G, TrustPilot "Excellent experience, would recommend no problem at all." Jason S, TrustPilot "A good experience and I believe this is my 3rd year. Still very satisfied with price and most particularly the service and general absence of machines answering the phone! People are always best and it's always a pleasure to speak to the helpful friendly staff." Mr Cresswell, TrustPilot
  27. Yeah - re-used the nuts. The other side is still at torque, lord knows what happened here. Ordered a couple new OEM locknuts for peace of mind. Well I thought I trusted it! Its a Draper and had it for yonks. Could probably do with checking that. Isn't the sump made of Alu? I'll fill it in and give it a paint anyways.
  28. Ouch. Original nuts reused on end of ARB? Do you trust your torque wrench? Looks like dent and scrape, but not much material lost. Sump is not leaking at that point, but probably worth reinforcing with filler and painting over to stop rust from outside.
  1. Load more activity
  • Create New...
