Jump to content
erixtar1992
bike carbs pissing fuel out of overflows
Recommended Posts
erixtar1992
yo.. right..
put cbr600 bike carbs on my mk2, i have checked all jets and they are clear and float bowls seem to be sealing fine when i checked them.
now, the car will start up and rev happily when the float bowls are NOT completely full of fuel
but when they fill up, the car will bog down, and fuel will start pissing out of the breather pipe on the top. if i hold my finger over the pipe then fuel will come out of the brass tubes next to the trumpets.
i am fuelling it using the standard mk2 mechanical fuel pump, and a y piece with the carbs + return on the y and the fuel inlet pipe on the straight part.
i can blow down the return line but i have to blow quite hard.
ideas?
Edited by erixtar1992
Share this post
Link to post
Share on other sites
Cymro
too much pressure.
i know your using the t-piece so there might be a kink or blackage in the return hose.
Share this post
Link to post
erixtar1992
like, i can blow down it not too hard, but if i try and blow harder it wont have it lol
Share this post
Link to post
erixtar1992
think it may be the return causing the problem
i put the return pipe into a fuel can and it stopped the problem... nalf filled up quick though haha.
sourcing the blockage is gonna be a pain though..
Share this post
Link to post
Cymro
check your FB. :lol:
Share this post
Link to post
erixtar1992
bit dark to do it now :/
pissed off as i needed the car to drive to work tomorrow. gonna have to get the train now which is long!
Share this post
Link to post
Cymro
I'm still suspect of your swirl pot being the cause. Ill smash open the broken one i have here tomorrow and see what the valve thing inside actually does.
Share this post
Link to post
erixtar1992
yah but when usiing t piece it does it too
Share this post
Link to post
harris.racing
So it runs better with return into a pot?
Too much pressure or float heights, did you bother taking the floats out and checking how clean the taper is on the float needles?
Share this post
Link to post
erixtar1992
checked the taper, was spotless on all four.
yeah it ran fine with the return straight into a fuel can which makes me think too much pressure is building up
Share this post
Link to post
harris.racing
Hmmmm you need that return freer flowing!
Share this post
Link to post
erixtar1992
yep. the return is stopping me driving to work tomorrow :(
Share this post
Link to post
Cymro
what ID is the return?
I'm still thinking there might be a kinked line somewhere, even the slightest kink will raise the back pressure.
Share this post
Link to post
erixtar1992
6mm i think.
yeahh its just finding it that will be the problem lol
Share this post
Link to post
Cymro
6mm is huge. :lol:
Have a look where it goes under the car from the engine bay, mine used to try and kink there.
Share this post
Link to post
erixtar1992
both my inlet and return are 6mm on this, on my later mk2 they were 8mm.
just had a look under the car with a light and couldnt see anything abnormal :(
Share this post
Link to post
harris.racing
I couldnt even blow down the return on my 6n, strange.
Hmm thinking
Share this post
Link to post
erixtar1992
wierdd.
do you agree that it sound like its fuel pressure related?
Share this post
Link to post
Cymro
Hmm thinking
Bigger Lungs? :lol: :lol: :lol: :lol:
I'm a brass player so its no problem for me. :lol: (very careful wording there) :nod:
Share this post
Link to post
harris.racing
Meh lol.
I'm thinking Eric, I'll prob phone you about 4am when I have a sudden realisation
Share this post
Link to post
erixtar1992
SHE LIVES!
i swapped the fuel pipes around and somehow its fixed the problem LOL
Share this post
Link to post
Cymro
Strange. :lol:
where were they wrong?
Share this post
Link to post
harris.racing
I did consider that but assumed you'd have checked lol
Share this post
Link to post
Cymro
i told him to check the swirl pot as well.
Share this post
Link to post
erixtar1992
Strange. :lol:
no i mean i swapped the fuel inlet pipe to the pump for the return pipe :lol:
for some reason its sorted it? return pipe must have been causing a little too much back pressure?
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
  • Create New...
