Jump to content
Sign in to follow this
ELAD
Engine rebuild
Recommended Posts
ELAD
Hi all,
I have a 1.3 6n I'm thinking of scrapping and want to keep the engine to put into my 1.0 coupe. When its out of the car i'm thinking about stripping it down and rebuilding it. I was just wondering whats the main components that you would change/upgrade?
Elis
Share this post
Link to post
Share on other sites
george_m3
this is a very vague question in my opinion. you should search and see what you want to do to it if you want to rebuild it. do you want to do the bare minimum as in take it apart and if components like piston rings, main bearing and big end bearings are in tolerance just put the thing back together? disadvantage of that being the engine may be worn and loose a small amount of horsepower not rev as smooth as it did brand new. or replace rings and bearings and freshen the engine up a bit. or you could get the engine re bored and buy oversized pistons this will get you closer to a as new engine. obviously gaskets, stretch bolts, o rings will be replaced whatsoever
in terms of upgrading again you should read up. there are a lot of things that can be done to these engines. cams, bike carbs, lightened flywheels. vernier pulleys, exahaust manifolds. also as your having your engine apart you have blueprinting that can be done, lightening of internal components and porting and polishing of heads.
Share this post
Link to post
paulspolo
rings, gaskets, stem seals, big ends, white metal bearings, hone the liners and clean all carbon of valves pistons etc that would be the simple things
Share this post
Link to post
steveo3002
+ valve guides maybe oil pump
will end up costing £££££ to do a half decent job
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
  • Create New...
