Jump to content
Engine turning over but not igniting
Recommended Posts
My Polo is not starting. It turns over fine but is just not igniting, I have a Mk 3 Polo 1.6CL. Any ideas to isolate the cause?
Share this post
Link to post
Share on other sites
First you want to find out if its ignition or fuel. I'd take the ht lead that goes between the coil and distributor and unplug it on the distributor end and place the metal piece in the end near something metal, get someone to turn the car over and see if it sparks/arcs. Don't be touching it when doing this either, if it decides to shock you you'll notice.
if you have a spark then take the spark plugs out one by one and do the same with the ends of those. You can use the rocker cover to try to arc them too.
If the spark plugs do spark check you're getting fuel. I'm presuming your engine is multipoint fuel injection here. The way to guarentee if it's getting into the engine is to take the injectors out one at a time and place pointing into a jar, turn the car over and see if it sprays a bit of petrol. Hope i don't need to say don't have any ignition wires or anything unplugged while you have injectors out and turning the car over and just generally use caution.
Report back with the results and with any luck you'll get some more help. Goodluck with it.
Small edit: The spark from the spark plug wants to be a blue colour, if it's yellow that could also mean something for getting a diagnoses.
Edited by joe420
Share this post
Link to post
Would you be kind enough to elaborate how it won't start? I had the same probs for weeks and finally got it going.
- What year is your polo?
- does it crank like normal and when you step on your pedal, it fires up for a second or two then dies out?
- Do you have fuel in the tank?
- When you turn the key ON, do you hear the fuel pump underneath the passenger seat at the back seat running or priming?
- Did you notice your engine light ON before it didn't start (while it was still running)
- do you have spark to your plugs?
I am sure there are a lot more but these could get you started with the isolation.
Share this post
Link to post
Thanks will see if I can chance to try these out in next couple of days.
So far I have noticed that it doesn't fire up at all and yes I have heard something running when I turn the key on.
Share this post
Link to post
Hi, the misfire might be from the Ignition coil ...just I substituted it on my Polo
Share this post
Link to post
You are commenting as a guest. If you have an account, please sign in.
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoticons maximum are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
  • Similar Content
    • Srinivas Merugu
      By Srinivas Merugu
      Hello Everyone,
      i have the same problem with my Polo MPI 1.2L Petrol, 74bhp (MK4 Platform). Starter cranks but I don't see RPM needle going up. Only after 3 to 4 times needle goes up and engine starts.
      When it starts RPM needle struggles to sustain at a single point and gradually after some time it settles at 900 RPM.
      What could be the cause, below are the few points which might help you:
      1) I have recently changed the battery with new one.
      2) This usually happens if I leave my car for 24 hours
      3) It struggles to start from cold starts
      4) When  engine starts I can smell smoke; generally I don't smell it on warm starts
      5) Do you suggest pushing throttle while starting the engine; generally I don't do it.
      6) is it the problem with Sparkplugs, ignition Coil or anything else...
      Kindly suggest.
    • Flappjak
      By Flappjak
      So I replaced my exhaust valve ground it back in properly then built everything back up to correct torque, timed up to correct marks the spun the engine by hand 2 revolutions then did another 2 just to make sure nothing catched, there was a lot of compression at one point where it felt like the valves had touched but they weren't, so I went to start the car, it was turning over fine and was firing as it back fired through the intake manifold but wouldn't start, I'm just after help as to what could stop it from starting? I've been told If they're hydraulic tappets that they need to be charged as the head was tilted on its side for two days and lost the oil
      thanks in advance
We have placed cookies on your device to help make this website better. You can adjust your cookie settings, otherwise we'll assume you're okay to continue.
