Jump to content
thomashenson
EPC Light Polo 9N - What does it mean?
Recommended Posts
thomashenson
Car been running fine lately, even with all of the cold weather. However, just recently i've noticed that the EPC light has come and i'm not sure what it means. Looked in the manual and it says to take it to VW garage to get it checked.
Any ideas?
Did some research and a lot of people are saying its a faulty brake light switch, but as far as i know brakes are working fine.
Thanks,
Tom.
  • Like 1
Share this post
Link to post
Share on other sites
caretakerplus
You need to check for fault codes to see why the light has come on. It might pay to do that ASAP.
Regards
Share this post
Link to post
kwijibo_coupe
Either find someone with a code reader that can tell you what is wrong or alternatively buy one yourself.
You can get something cheap on eBay like this http://www.ebay.co.uk/itm/U281-VW-Audi-Skoda-Seat-VAG-CAN-BUS-Fault-Code-Reader-Scanner-diagnostic-tool-UK-/221040985066?pt=LH_DefaultDomain_3&hash=item337711c3ea
If you post the code up on here someone should be able to tell you what it means and how to fix it.
If you go to VW they will charge you an initial fee of something stupid like £70 to read the code plus then whatever the car needs to fix it.
  • Like 1
Share this post
Link to post
prankstar2003
I had a similar problem a few years ago and it turned out to be the brake light switch. I'm not saying this is it, but the fix is easy and relatively cheap. Could be worth doing before you spend too much money
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
  • Create New...
