Jump to content
Sign in to follow this
CraigAnderson
Cbr600 keihin carbs running problems
Recommended Posts
CraigAnderson
I know there's a huge section in FAQ about bike carbs but I was wondering where the carb balancing kits connect to on keihin carbs cus I don't have vacuum pipes on my inlet, Cus I don't want to buy a balancing kit and I got no wear to connect them to ? Plus my car keeps popping loudly and coughing and spluttering and shooting flames from the inlet, It sounds almost like the spark is out but timing of the engine is spot on but I guess its because my carbs are not balanced. I have a remote fuel regulator set for 2.5bar and any higher fuel pours out the tiny brass tubes as am guessing that's the overflow.
Am running 150jets and needles are untouched on top
Share this post
Link to post
Share on other sites
dvderlm
If you can find take off points, or just rest tube ends in the inlet throats and hold in place with clothes pegs, this solution works well...
$1.55 carb balancer
http://powerchutes.com/manometer.asp
actually might cost a bit more if use green virgin olive oil to make the fluid more visible
Share this post
Link to post
dvderlm
2.5 bar ????
but that's 36 PSI over atmospheric. Arbroath is not that far above sea level surely...
None bike twin carbs need under 6psi (0.4 bar) fuel pressure.
Edited by dvderlm
Share this post
Link to post
CraigAnderson
I need new jets and pilot tubes for keihin vp carbs, And if you look at the picture should I have them extra wide holes on my pilot tubes ?
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
  • Create New...
