Jump to content
Sign in to follow this
rustnroll
16v 1.4 Overhaul
Recommended Posts
rustnroll
Sooo, did a complete overhaul on my 1.4 16v. Clutch, timing belt, drivebelt, had to rebore manifold threaded holes as they were knackered.
Turned it on for the first time yesterday and it made some horrible noises.
I think I have messed up the timing as when the engine turned over the first few times it sounded as if the pistons or maybe valves were pumping/operating at a much higher speed than the engine. Very strange. Also with the top cam cover off the belt spins slower than the drivebelt. I am confused and also concerned.
HELP?!
Share this post
Link to post
Share on other sites
wizardmanjm
Can you post a video to explain this perhaps through photobucket or on tapatalk?
Have you got enough oil in? When you fill the engine with oil it will appear level on the dip stick until you start the engine and it starts to circulate then it appears you need to add more as it will more than likely fall below mimmimum on the dip stick
Sent from my SM-G925F using Tapatalk
Share this post
Link to post
steveo3002
first thing i would do is turn it over with a spanner and double check the timing marks ...then check again to be sure
Share this post
Link to post
rustnroll
Thanks guys.
How do go about resetting everything to TDC and be sure that it is?
Share this post
Link to post
steveo3002
surley you checked this when fitting the belt ?
anyway turn the engine with a spanner on the crank and watch for the marks to line up  , haynes manual should should you the marks , there will be one on the crank and another on the cams , they need to line up exactly otherwise the valves hit the pistons
Share this post
Link to post
rustnroll
I checked but not thoroughly enough. Assumption is a dangerous and stupid thing. Thank you for the advice. I'm gonna go play and see if I can get this back to normal.
Share this post
Link to post
steveo3002
good chance its done damage if you tried it with the belt on wrong ,  i always spend an extra 10 mins and check it again just to be 100% sure
Share this post
Link to post
rustnroll
thanks for all the help guys, the beast is running!
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
  • Create New...
