Jump to content
Sign in to follow this
VWPoloG
Engine timing question
Recommended Posts
VWPoloG
Hi everyone,
I have a 1994 VW Polo AAU and I've just replaced the distributor. I wanted to check the engine timing was OK. With a timing light I manage to take some photos. In my Haynes manual it has a very different diagram for engine timing points which I think refers to a different engine code.
Could I check with you guys that it looks OK and its in the correct position?
Thanks for your help!
Share this post
Link to post
Share on other sites
rodeater
Does it have vacuum advance on your dizzy if so unplug it then check your timing at idle there will be 2 marks normally one says o.t you don't want that one as it the tdc mark you want the other one if you only have one the mark will be on the flywheel
Share this post
Link to post
VWPoloG
No vacuum advance on this dizzy. It has only a single notch on the flywheel.
Does the timing look OK?
Share this post
Link to post
nige8021
The timing should be set @ 800rpm and be 5+/_ 1 deg
91EDAE38-A04B-451E-A8FD-6AAAAB20890B_zps
F330DFEF-2FD2-4AAE-812F-0E6264207246_zps
Share this post
Link to post
VWPoloG
Thanks for responding nige8021. Unfortunately my Polo is the basic model and the instrument cluster/dashboard doesn't come with a rev counter so I don't know what we are reving it to. Is there a another way of finding out?
According to our very basic measurement: We think the degree of change (idle to throttle open) is 8.5 @ unknown rev.
Looking at your diagram I thought the timing mark should be moving from A to B in our photo, but it seems way out. Could this suggest timing is off? I mean the car sounds fairly healthy when turned on.
Share this post
Link to post
nige8021
800 should be idle speed,  from your diagram it looks like @ idle your about 15deg ATDC rather than 5deg BTDC  You can get timing lights that give you a rpm readout
Share this post
Link to post
VWPoloG
Thanks for your reply and diagrams, they were very useful. I manage to get the timing sorted (almost). The engine seems to have erratic idling, on a few occasions the rpm increased (unsure what to) but as if it was accelerating. I had a quick look around the throttle body and I noticed the crankcase breather hose was damaged.
Will this be the reason for idling too high?
I can't seem to find instructions on how to replace the breather hose in the Haynes manual. Do you know if it could be referred to by a different name?
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
  • Create New...
