Jump to content
Sign in to follow this
Jawi91
Best option for Clutch cable replacement
Recommended Posts
Jawi91
Hi Guys,
The clutch of my VW Polo 6N2 2001 is verry stiff/rough and i want to replace it with new cable but i dont know if i should get a Self adjusting cable  or a manual adjusting cable from seat or something.
what would be best to make it smooth again
thanks in advance.
Share this post
Link to post
Share on other sites
nige8021
Before you replace the cable, have a good look at the hinge point on the pedal, get a good torch and look for cracks around the pedal box as this is known weak point and was a dealer recall for a replacement pedal box
Share this post
Link to post
Jawi91
Will have good look than before i spend money on a new cable.
Thanks again nige8021 :)
Share this post
Link to post
Jawi91
I can't see any crack's or anything the car has 100.000 km on the clock and i got it since 60.000 so its not that old. i think it might be the cable than. do u know the part number of the original cable by any chance? will it be best to get the self adjusting or a manual adjusting cable?
Share this post
Link to post
Jawi91
i orderd a manual clutch cable for ibiza 6k/6n2
Share this post
Link to post
PHIL SWARBRICK
Also, don't rely on the lube supplied in the cable. Use a silicon (won't rot plastic parts) oil and add it to the cable. It's made a big difference to my Mk2 cable. Easier on the left foot and freer running.
Share this post
Link to post
Jawi91
I was already planning on doing so :) i want this clutch to go as smooth as possible again. I was really fed up with amount of force needed to engage te clutch.. got new cable for only 35 euro :) there was a discount on it so that was nice.
Share this post
Link to post
Jawi91
So i fitted the manual adjustment cable today and iam not sure if i can lube it or not.. some say its bad for the coating on the cable?
Share this post
Link to post
Jawi91
its fitted and mannnn its smooth as butter now :) spray it with aligator spray its good lube that replaces silicon spray.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
  • Create New...
