Jump to content
Recommended Posts
Eviljohn
Hi polo people. Hope you're all very well indeed. Looking for some guidance on my '83, 1043 breadvan if anyone can give any. Tried to start her up the other day. Turns over just fine, doesn't catch. I noticed the fuel filter was empty. Checked the filler cap for negative pressure, no hiss when i undid that. Got hold of a new fuel pump, (ebay,) fitted that, no difference. Still just turns over doesn't start. I did take the inlet pipe off just before the new pump and put my finger over the end to see if it was sucking and it wasn't. No idea if that is normal, seemed like a good idea to try it. Had a look under the car, can't see any puddles or obvious leaks. Fuel gague says there is fuel in the tank. I still have the pump i took off. Cam belt looks intact and not slack but i didn't actually take the cover off to check yet. Is there anything else i can check? Carb is a weber, had it refurbed couple hundred miles ago. Thank you for stopping by and any guidance you can give me. Take it easy.
Share this post
Link to post
Share on other sites
caretakerplus
If the old pump didn't 'suck', when it was on the engine (1) Try it again now that you have removed it (2) If it works now, you really must check that the camshaft is rotating!
You could connect a short length of PETROL hose to the inlet of the new pump, submerse the other end in a small container (not plastic) of petrol and see if that picks up IT MIGHT BE A GOOD IDEA NOT TO SMOKE WHILST YOU DO THIS !!!
There is JUST a chance that the pipe to the carburettor is blocked, or the needle valve in the carb is jammed shut- that in itself would prevent the pump from 'sucking.'
You could also try 'dribbling' some petrol into the carburettor air intake as the starter is being operated - if it fires, the problem is definitely lack of petrol.
Requirements for an engine to run: (1) Supply of petrol to the ENGINE (2) Supply of air (3) Compression (4) Correctly timed spark.
Regards
Share this post
Link to post
Eviljohn
Cool. I have a spare bit of fuel hose. I'll try that. Nearly started with a squirt of easy start the other day, (have since stopped using it as someone told me it actually damages the engine.)
Thanks dude.
Share this post
Link to post
Eviljohn
Kay. Did some checks today:
Took the cam belt cover off while i tried to start her up. Cam belt and whatever the wheel is called both went round.
Took the top off the carb, checked the needle and the float. Chamber was empty, needle seems to move freely.
Took the inlet fuel pipe off the new pump, sucked on it, got fuel in the filter and a s**tty taste in my mouth. Haven't had chance to take the cam cover off to see how the fuel pump lines up.
If the cam belt turns when i try to start, does that rule out an issue with the camshaft?
Do the checks i've done point towards the issue being the fuel pump?
Thanks for stopping by and any guiidance you can give. Take it easy.
Share this post
Link to post
dvderlm
odd. could not see what i was replying too with this new layout!
maybe lost internet connection during edit...
Empty carburettor chamber says fuel pump if needle valve and float and fuel line okay.
The camshaft pulley turning in synch with the crankshaft pulley, should mean the pistons are moving up and down and the cam lobe is pushing the fuel pump rod.
If you turn the crankshaft clockwise with a socket on the pulley bolt through the offside wing access hole you should feel the resistance of compression stroke with sparkplugs in as valves close.
So there's only spark at the right time which if you have not disturbed distributor or moved plug leads should be the same.
Don't drink petrol.
Edited by dvderlm
Share this post
Link to post
Eviljohn
Have not moved dizzy or leads.
Next chance i get i'm looking to take the cam cover off to see how the camshaft and fuel pump mate up. If they aren't meeting up properly, for whatever reason, that'll be the issue.
Also looking to check return line for blockage.
Pump i had in place was donated. Think it came off an early golf. No idea which one. Was having running issues at the time and a local mechanic that was giving me guidance said i could try replacing the stock pump with that one to see if that sorted it. Pump didn't make any difference at the time.
New pump is off ebay.
Could the wrong pump, as in one that was meant for a similar car but not this actual car, have done something to damage/wear down the camshaft lobe it was mated up to?
If so, could it be the way i fitted either the donated fuel pump or the new fuel pump?
Thanks again for stopping by and the guidance. As always, much appreciated and invaluable.
Share this post
Link to post
Eviljohn
Also, would a blockage in the return pipe cause enough pressure to stop the pump from pumping on startup?
Share this post
Link to post
dvderlm
No, return line blockage would only have an effect once carburettor float chamber filled and needle valve shut off the flow.
You'd need something catastrophic to wear down the pump lobe, it's more if an eccentric circle, so there's no sudden change, unlike a valve lobe's steep ramps.
I used a tyre pump to clear the fuel lines. Should be able to hear it bubbling in the tank (over noise of the pump)
Are the fuel lines old and covered in cloth braid...?
Wipe them with a tissue to see if there's a hidden leak (especially near any clips) exposed by disturbing their route.
Edited by dvderlm
Share this post
Link to post
Eviljohn
That rules out return line blockage then. Probly worth checking anyway just to see how it is.
All fuel lines in the engine bay are new. Couple of sections have fabric overbraid but i'm looking to change that for plain fuel hose when i get to it, so i can see any leaks easier
Fuel line running from the fuel tank and return line running parralel are both green plastic until they hit the bay. Then it's the fuel lines i've put in. Braided or otherwise.
No idea what the green plastic ones are made from. They were on the car when i got her. Pretty much covered in road scuzz under the car. But no apparent leaks. No puddles where i've parked, no wet spots in the scuzz.
Did you just disconnect your fuel line from the fuel pump, hook it up yo your foot pump and pump away to clear and scuzz?
Share this post
Link to post
dvderlm
yes disconnected from pump, pushed an adaptor for paddling pool in the tube and turned on the electric pump.
Doubt you'll get a foot pump hose to reach as you want to keep the open pipe above the fuel level in tank normally.
Share this post
Link to post
dvderlm
If you dribble a bit of fuel down carb throat will it fire?
With  easystart it's easy to get the wrong idea about the state of the carburettor mount seal.cause you have to keep  the throttle plate opened.
Wondering whether there's a vacuum leak, carb base mount is typical weak point.
Concentrate on getting the carb chamber filling.
Share this post
Link to post
Eviljohn
Haven't tried manually filling carb yet. Will do though. No idea about the carb mount. Worth checkin out though. Thanks for that.
Share this post
Link to post
Eviljohn
Turns put there's a split in the carb mount. Fairly decent sized split. Had chance to get under the bonnet today. Was going to check fuel return line for blockage. Just leaned the carb back gently and i could see the front mounting bolt that's meant to be underneath/inside the mount. Split is literally just a split, wouldn't have spotted it if i hadn't moved the carb. But it's about 1cm in length. Does that fit with empty float chamber and fuel pump not pumping?
I have a new one on the way. Once fitted, i'll try it with the old fuel pump first and see how that goes.
Share this post
Link to post
dvderlm
That should sort it. Go gentle on the mounting bolts. Some rubber seems more prone to splitting.
Engine  cranking should fill the bowl, but it fills faster at 950rpm idle (or higher on choke) than 250rpm crank speed
Share this post
Link to post
Eviljohn
Cool. I'll get that in place when it arrives and see what happens. I'll put the old fuel pump back on first to see if that actually still works.
Thanks for your help so far.
Share this post
Link to post
Eviljohn
Mount that turned up was too small for inlet manifold. Properly struggling to find another one. I had already planned to put bike carbs on this summer and actually have most of the parts i need already. I have someone happy to help me do it but i may have to get the car to them. If i patched the leaky mount with either gun gum or a gasket maker, would that work just to make that one trip? The leak is literally just a line along a seam. Can't see it just looking at the mount on it's own. The trip would be 121 miles on motorway and A roads. Would that hold?
Share this post
Link to post
steveo3002
patch it with pu sealer /tiger seal ....toolstation /ebay sell it , imagine it will last as a temp repair if you clean it well
Share this post
Link to post
dvderlm
Have you got breakdown cover? Do a short trip with the temp repair first  - like a circle not more than 2 miles from home.
Engine has suction of 40 Hoovers (or 50 EU vacuum cleaners)
Share this post
Link to post
Eviljohn
I have fully comprehensive rac cover. That's my current plan B if i patch this leak and it stitches me up on the way to getting fixed. Can get a tow the rest of the way.
I've put some wynns black rtv on it and i'm leaving it to cure. If it works well enough to get her started, that's awesome. If it holds for the road trip, even better. But if i take her for a little run and the wynns fails, it's easy enough to take it off and put something else there instead. Tiger/pu seal.
Thanks for the advice so far chaps. I'll be back with results. Have a great weekend.
Share this post
Link to post
Eviljohn
Kay. Had a chance to tinker this morning. On Friday night i put some wynns black on top of the carb mount to seal the split and left it to cure, which it did. Yesterday, it crossed my mind that where the split is, unless it's bigger than it looks underneath, it shouldn't really be an issue as the split was on top of one of the bolt holes that connect the carb onto the mount, pretty much a seperate hole from the inlet opening. Anyhoo, by then wynns had cured. I cleaned mating faces of carb, carb mount and inlet manifold. Using hylomar blue to seal, put them all back together.
While the hylomar was curing, i checked over the fuel hose in the bay again. Still had some cotton braided stuff but as it looked tired and cracked on the ends, switched that out for new, non-braided. Also put new fuel filter in. Checked that new fuel pump was sucking, which it was. Once all was back in place and secured, fired her up. Fuel filter filled with fuel, few tries later, she fired up just fine. So it was either leaky carb mount, blocked fuel filter or shitty fuel hose that was the culprit.
I can now keep an eye on fuel lines better with non-braided hoses.
Fuel pump should be fine as it's new.
As is fuel filter.
Carb mount and carb will be going soon anyway as i have bike carbs lined up to go on very soon.
Thank you for your guidance. For now she is alive and running again. Haven't taken her for a long run yet as i haven't got chance to for a couple of days. Will report back if any issues arise. Won't go very far, just in case it is the mount as i need that to hold for the journey to get bike carbs fitted.
Thanks again polo people. Take it easy.
  • Like 1
Share this post
Link to post
Eviljohn
So i managed to take the beige beast for a run this morning. Ran just fine. Not sure if it was the fuel lines or carb mount that was the issue. Will come back with any info so any one else can compare.
Thanks again for your help peoples.
  • Like 1
Share this post
Link to post
dvderlm
Carb mount.
You can leak petrol - for a short period - you can't leak air.
Share this post
Link to post
Eviljohn
Most likely. Had it before and it fits symptoms. Only reason i considered other possibilities was the position of the split in the carb mount and the state of the ends of some of the fuel lines. But yeah. Carb mount is most likely suspect. Will be going next week anyway as i have all the bits ready for bike carbs. Will have a little shufty then to see if i can figure it out for sure.
Share this post
Link to post
dvderlm
Search for beige beast polo on youtube.
Share this post
Link to post
Eviljohn
Dude, i've seen that! G40 innards in a bready. Would love to do similar at some point.
Share this post
Link to post
You are commenting as a guest. If you have an account, please sign in.
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoticons maximum are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
  • Similar Content
    • MK2FKieran
      By MK2FKieran
      Hi everyone,
      Little background story.. when I was 17 I hastily bought a terribly painted purple breadvan, drove it 4 hours solid home and brought it to Lancashire. I sold it a long time ago and recently on my 21st birthday found out it was for sale so bought it back! (Slight downgrade from the abarth but the sentiment this car his is unbelievable). Now to cut it short, the car was a stead and never once let me down.
      I towed the car back to the garage, it’s been off the road almost 3 years, and was apparently in “dry storage” however, there was litres of liquid under the back seats, rust and damp everywhere and a lovely infestation of maggots in the firewall. Regardless, I put an old knackered mk1 fez battery up, hooked it up to a jumper and first go started up, although it was running on 3 cylinders. I then put a new dizzy cap on (correct and correct firing order), new plugs , battery and changed cylinder 4 HT lead as it wasn’t sparking hence the 3 cylinders. The problem is the car now won’t start and the plugs are getting seriously wet, it just comes gushing through, after drying the plugs many times and trying to run it solely on ether still no joy! (I forgot to mention, 4 gallons of old fuel it started up on. Have since drained and refueled as well as cranked the crap out). I was just wondering if this is a common problem or anyone has had the same? Any help massively appreciated! The car has covered 171k. Thanks!
    • NebulaicToaster
      By NebulaicToaster
      I did a full head gasket change recently, new gaskets seals water pump belt and skimmed serviced head. After putting her all back together and fixing an ignition problem she is still running a little rough I think (I can't tell if it's a normal running sound because I've never owned a polo before and she was in this condition when I got her). I took her for a test drive yesterday and after starting up and putting the choke in she kept stalling going into first. I had to put a load of revs on to get her to move. After driving for a bit it stopped being an issue. I colourtuned the engine before the head change, should I retune now the head has been done (the leak was on cylinder one front right), and could it be a mixture problem? I also put a pierburg carb on to replace the old one (another 1b but with manual choke and no external reservoir, maybe the reservoir is causing the lack of fuel to the cylinders)? Sounds like it could be a misfire but I've got the timing bang on and all the plugs are getting electric (got a stroboscope) so maybe I've cocked up the head gasket? I've got a compression tester now and I'll do one after the weekend, I really hope it's something carb related though because the head was a pain to do . ..
      It's a MK2 1.05 HZ bready
      Thanks for all your help with her, sorry for the mountain of questions, just want her to be the best she can be!
    • Unico7n
      By Unico7n
      For sale
      Near mint Mk2 ranger interior includes seats and doorcards
      looking for £100 Ono or can do a deal if you have the right rear bench and door cards to part with
    • Mullen29
      By Mullen29
      Hi everyone,
      This is the start to my project of which I hope to complete through this year/ start of next year! It is going to be raced with the hopes to be able to be one of the quickest cars out there, the video below is what I'm against from, 120 ish micras to high reving fiat  unos! its not gonna be the easiest to be able to get up there but I think I can accomplish it? it is going to be fully spaced framed with the only bits belonging to the car being the panels and engine, but even the engine is going to be modified: with the hopes of getting it to rev to 9500 rpm with out shitting a rod lol!
      Sunday 7th of January:
      I bought the car and got it home and it is now sat out side, and will be sat there for another 2 weeks till I start to strip the remaining items off the shell and get ready to chop the floor and make a start to the space frame! (IF all goes to plan)
We have placed cookies on your device to help make this website better. You can adjust your cookie settings, otherwise we'll assume you're okay to continue.
