Jump to content
VW 1.4 tdi intermittent starting problems
Recommended Posts
Louiss_wilsonn
Hi
I recently brought a 6n2 1.4 tdi polo, had massive problems with starting the car, turns out it was the battery as it was only 40ah battery! So I got that replaced and everything was fine, but recently it's doing the same, it just cranks over fast but doesn't fire, sometimes it does it, sometimes it doesn't or it starts then dies about 2 seconds later and flashes up a battery light icon, I changed the fuel filter when I done the battery, any ideas what could be causing this?
Thank you
Link to post
Share on other sites
  • Louiss_wilsonn
    2
  • nige8021
    2
Popular Days
Popular Posts
First Welcome to the forum.   Starting and dying 2~3 seconds later is classic immobiliser kicking in and killing the engine, I would start by seeing if there are any stored fault codes, espe
nige8021
Starting and dying 2~3 seconds later is classic immobiliser kicking in and killing the engine, I would start by seeing if there are any stored fault codes, especially any relating to "Start blocked by immobiliser" When you have the fault code/s post them in this thread and we can go from there.
  • Like 1
Link to post
Louiss_wilsonn
Thanks for replying nige, thing is it's only died after starting twice since I've changed the battery(4 days ago) some of the time it cranks over but doesn't fire and most of the time it starts perfectly fine, unfortunately I don't have a code reader :( I have read somewhere about either a fuelpump relay/ecu relay/crankshaft sensor/engine temp sensor, or potentially the alternator on the way out? There does seem to be some dodgy wiring connecting to the alternator
Link to post
nige8021
There are many things that could be causing your symptoms, as I said earlier it does sound like a classic immobiliser problem, but without checking for any fault codes you could be replacing sensors/other items (£££'s) for no good reason.
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Announcements
  • Create New...
