Jump to content
JonWaite
Air/fuel mixture issues Mk2f
Recommended Posts
JonWaite    0
JonWaite
Hello,
cutting a a long story short, my car (Mk2f AAV) hasn't idled or drive right for some time, so changed fuel filter, spark plugs, distributor cap and rotor, new leads, oil filter, blue temp sensor and it go no better.
my local mechanic ran it through diagnostic and it just told him the air/ fuel mixture was all over the place, however it didn't tell him anything specific. He's recommended I take it to a specialist.
So, has anyone come across anything similar to this? Before I take it to my nearest specialist
cheers
jono
Share this post
Link to post
Share on other sites
steveo3002    349
steveo3002
any better if you unplug the o2 sensor?   was the blue temp sender a good brand?
Share this post
Link to post
JonWaite    0
JonWaite
I've managed to have a day off with no rain!!
Anyway, the car runs better without the o2 sensor, so I assume it means I need a new sensor?
ive only being buying well known branded products, I like the car too much to kill it with cheap parts ?
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
  • Similar Content
    • chopperoli
      By chopperoli
      Seeking a pair of these spring top caps which lower ride height by 5-15mm
    • 1vw2many
      By 1vw2many
      Hi just thought I share a few photos. I brought this last November 2016 came with 8 months mot for the grand some of £25 plus £70 for delivery as it was to far for me to fetch. I brought parts for it over the next few months as I wanted to replace most parts.
      Petrol tank
      Ap 40/30 shocks and springs
      Drivers door
      Anti roll bar bush
      Strut top mounts
      Lower control arms
      Steering arms
      4 Cv boot kits
      Disk brake back plates
      4 Flex brake lines
      4 brake hard lines
      Brake fluid
      Rear drums
      Rear brake cylinder , shoes bearings
      Front disks , pads , new piston seals , bearings
      All hand brake cables
      Centre silencer
      All parts I brought were Pagid , meyle or febi
      1st few photos are how I got the car. Person I brought it off plays rugby in site of the car was half of the rugby field.
      Passed its mot on Friday ..
    • jscmk3
      By jscmk3
      Wanted: Standard rear light unit for Mk2f Coupe, right hand o/s.
      This is to help out an elderly lady in her 80's who has had her Polo Fox Coupe since new. Have been let down by an ebay seller and now in need of one urgently as her MOT is about to run out and will not pass without.
      Any help appreciated.
    • 1vw2many
      By 1vw2many
      Looking for engine code on mk2f,  is it under the dizzy?
    • JoshKirkaldy
      By JoshKirkaldy
      Welcome to my build thread, I have started with a standard 1.0 4 speed thats being converted into rwd with a complete engine and gearbox swap. Info on what engine and gearbox im using wont be revealed until its completed. I will update as i go along with a lot of parts being made up from scratch and photos of lots of the build parts.
