Jump to content
mark_l_sanders
Gear Change Advice Wrong?
Recommended Posts
mark_l_sanders
I drive 2 Polo's regularly - a 2016 1.0 and a very new l.2 TSI.
With both, I've noticed that the central console doesn't advise a change from 4th to 5th until way after I'd naturally change up....yet I'd have thought that an early change would be better for economy etc etc.
Has anyone else noticed this - is the automated advice simply wrong, or are my driving habits probably the issue??!!
thanks
Share this post
Link to post
Share on other sites
kiran_182
I change at 8k.....
Share this post
Link to post
kiran_182
Anyway, the auto advice may be programmed to help them stay inline with goverment targets and pollution reduction
When do you normally change? Do you know where the power band is and chamge for that?
Share this post
Link to post
mark_l_sanders
Hi Kiran - I know I normally change many thousand revs under 8k!!
I'll check the next time I drive and post it here.
I don't know the power band - does VW publish these specs anywhere?
thx
Edited by mark_l_sanders
Share this post
Link to post
kiran_182
Aa 3.5 4k in a petrol is a fairly tame time to change
Power band is a small section of the revs where the most power is produced, some cars have it low down and then it drops off around 5k and others it comes in later and goes all the way to the top.
Changing in that band will get the best acceleration and economy suffers
Share this post
Link to post
dvderlm
Found some gear ratio specifications. looks like the 1.2 TDI has different 4th than any of the others so you stay in it for longer.
Peak power is at a mere 4200rpm and peak torque at only 2000rpm.
http://www.vw.co.za/content/medialib/vwd4/za/editorial/pdfs/brochures/polo/my14-polo-my14-spec-leaflet-2013-210x297-v5lr-pdf/_jcr_content/renditions/rendition.download_attachment.file/my14-polo-my14-spec-leaflet-2013-210x297-v5lr.pdf
Suppose it all helps the EU 5 Emissions rating.
I hate those nannying indicators (Nissan Pulsar PureShiteDrive) . They've no idea whether you are climbing a hill or trying to be ready to overtake a lorry or cruising up to a red light.
Share this post
Link to post
mark_l_sanders
Thanks, dvderlm - the engine I'm asking about is actually a 1.2 TSI petrol, so not the right specs unfortunately! Tbh, I've no idea if the indicator advice things are simply looking at revs or whether they cross-match rev with speed....
Share this post
Link to post
dvderlm
7 hours ago, mark_l_sanders said:
a 2016 1.0 and a very new l.2 TDI
ah, ok.
Tsi is turbo and supercharged I think or is that TFSI.
So there must be a crossover point where supercharger parasitic drag is overcome by exhaust speed spinning the turbine.
That would be start of optimal rev range for efficiency I suppose.
https://www.otodata.com/cars/Volkswagen/Polo-1-2-TSI/187583.html
has torque range but not gear ratios.
I hope there are sensors looking at engine load (manifold pressure) but even these can't read my intentions.
Edited by dvderlm
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
  • Create New...
