Jump to content
Connor13a4
Mk2 Polo Grinding Noise on Engine
Recommended Posts
Connor13a4
My polo has been making this grinding noise at idle and at a slightly higher revs
Share this post
Link to post
Share on other sites
steveo3002
hard to tell really...cam belt sounds a bit tight
you can whip the alternator belt off to eliminate that
Share this post
Link to post
Connor13a4
Have removed alternator belt and the noise is still there and the timing belt is adjusted correctly to 90 degrees with finger and thumb.
Share this post
Link to post
steveo3002
has it started sinse you did something or what?
Share this post
Link to post
Connor13a4
Welli have done the cambely and water pump and had to replace the water pump twice due to faulty parts
Share this post
Link to post
steveo3002
yeah sounds like the belt or pump to me really..
could try it a tiny bit slacker to see if it helps?    is it a known brand water pump?  and check all the teeth mesh properly as theres 2 styles of cambelt teeth , so could possibly be running a mismatch of parts?
Share this post
Link to post
Connor13a4
That is a v tech water pump from gsf and im pretty sure the belt matches up with the pulleys, i took the pump off last night and it had a little bit of play and a clunk noise when moving the pulley so changing that tonight.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
  • Create New...
