Jump to content
Recommended Posts
MonsterL35YFP
Hello, so I'm in the middle of replacing my head gasket on my mk2f with an AAV engine. By chance I was checking the thread on my new head bolts and it turns out they are 98mm long like the PY/G40 engine and the standard ones are meant to be 96mm long, now I'm stuck can I still use them on mine? or am I best to buy the right length for the engine code. The bolts are stamped with 8.8 tensile strength.
Link to post
Share on other sites
  • MonsterL35YFP
    2
  • steveo3002
    1
Popular Days
steveo3002
imagine too long will bottom out before theyre tight ...if they otherwise match up you could see if you can get 2mm machined off the ends ?
Link to post
MonsterL35YFP
Ok mate I found out they are for the earlier solid lifter head, I'm going to check how deep the block bolt holes are and if not I'll probably just buy some more they ain't expensive, cheers for the reply mate
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Announcements
  • Create New...
