Jump to content
ant6768
Removing cam cover from ahf engine
Recommended Posts
ant6768
 I plan to remove my rocker cover camshaft cover from my afh engine to paint
 Does anybody know its it juat unblots and replqce the seal on refit ? Or does the cover hold any down underneath it ? Thanks
Share this post
Link to post
Share on other sites
kwijibo_coupe
Yup, simple case of undo all the bolts and remove.
Share this post
Link to post
mbusby993
Worth noting that the gaskets are a pain if you’re planning on removing and replacing. If I remember right, they’re a “one piece” sort of thing with the cam cover? A lot of people have used sealant successfully...
Doing some digging shows these as the part numbers if you want to try and ring VW and get some new gaskets...
036 103 483 D
036 103 483 G
Share this post
Link to post
ant6768
 Thanks for your help guys I do not need to do the head gasket just remove the cam cover  to paint it  thanks again
Share this post
Link to post
mbusby993
I meant the cam cover gasket mate, if it isn’t sealed properly on refitting you’ll leak oil out of the cam cover...
Edited by mbusby993
Share this post
Link to post
ant6768
Oh ok thanks mate
Share this post
Link to post
You are commenting as a guest. If you have an account, please sign in.
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoticons maximum are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
We have placed cookies on your device to help make this website better. You can adjust your cookie settings, otherwise we'll assume you're okay to continue.
