Jump to content
Mk2 Coupé S project 1.3 engine performance help!
Recommended Posts
Hi
I’m relatively new to the polo scene but have build a reasonable amount of knowledge on them already. I brought a non running mk2 Coupé s as a project. The previous owner had done a 1.4 afh engine swap, but the cam belt slipped so has suspected bend valves etc. I am looking to swap it back to the 1275cc standard engine. So have brought a mk2f breadvan as a donner ( mostly for engine parts ) and am wondering what some of the best things I can do to that engine (and the car in general) to increase BHP, performance etc ?
Any help would be greatly appreciated. It already has a 5 speed gear box fitted.
Jack
ps sorry for accidentally posting 3 times
Edited by Jack1902
Link to post
Share on other sites
  • Replies 11
  • Jack1902
    6
  • MonsterL35YFP
    3
  • steveo3002
    1
  • kiran_182
    1
Popular Posts
You only need to change the inline fuel pump and maybe the front fuel hoses, everything else should pretty much bolt on
MonsterL35YFP
Hello, it mainly depends on how much you wish to spend and the donor engine I'm assuming it's the SPI (single point injection) in that case you could change to bike carbs or something along those lines, 4-2-1 manifold maybe be a GT cam or another performance cam but the best way to start is to give it a full service make sure all the HT leads are in good nick and your dizzy and rotor arm.
Edited by MonsterL35YFP
Link to post
Hi, cheers for the info. Yeah it’s got the spi system was thinking about maybe trying to find a gt injection system and also a gt cam as you mentioned. Also thought about getting the head ported and polished  so would probably benefit from getting a 4-2-1 aswell.
Link to post
MonsterL35YFP
Yeah all are a good for performance upgrades, with the GT injection system you have to get everything complete loom, inlet, fuel pump, injection rail, ecu  and not many people are willing to break them very often now but they did do a none GT engine with an injection system it was a HZ engine code and even some 1.3 MK2 golfs/jettas came with the same system so keep an eye out on eBay or on this forum.
Link to post
Yeah I’ll keep an eye out for the cam and injection
Link to post
steveo3002
if you havent sourced an engine then the 1400 abd is a direct swap and looks the same , all the gt parts fit the same etc
Link to post
4 hours ago, kiran_182 said:
Youll need to gt fuel pump too as the spi one cant keep up at full throttle
Mmm yeah quite a big job, might be one for the summer
Link to post
kwijibo_coupe
Since the car was previously running an AFH I'd say the fuel supply to the engine will be adequate enough to run the GT injection.
Link to post
Good point, it has been changed from original and also has a leak that needs fixing so I’ll check while I’m under there.
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Announcements
  • Create New...
