Jump to content
dvderlm
mk2 rocker arms/solid lifters - how can I number them 1 to 8?
Recommended Posts
dvderlm
I've got some new  rocker arms to match a new cam.
I'd like to mark them with numbers 1to8 so I can keep them matched to the same cam lobe.
They appear to be made of vibranium. Tried a 2mm hardened steel punch and it bounced off.
Paint will not survive oily environment and I don't have a diamond in my toolbox.
Ideas?
Share this post
Link to post
Share on other sites
Vedad1944
Don't want to sound dumb, and I have not tried this myself, but what about this?
  • Like 1
Share this post
Link to post
steveo3002
wouldnt they only need numbering when dismantling the engine for work??  in which case a dab of paint or store them in seperate bags/boxes
  • Like 2
Share this post
Link to post
Yeti
If it's not for long, get a cardboard vegetable box from the supermarket, flip it over cut holes in the base, insert the parts in the holes, write on the box what they are.
If it's for a while, get a load or drug dealer bags and label the bag. Keeps the moisture out and the oil in.
If you're feeling flash, you can get proper organiser trays.
Edited by Yeti
  • Like 2
Share this post
Link to post
dvderlm
Thanks. i have used an egg box for temporary head overhaul work before.
Think the new and old cam are going to be doing the hokey-cokey until I understand and can measure the actual lift of old then new. I'm not expecting it to be driveable straight off or maybe at all..
Unworn rockers and lobes, same base circle I think, but longer duration.
Also trying to work out if lash caps will be needed as the ramp is more aggressive and it is going to rev higher. Not as if they'll fit without attacking the vibranium rockers.
Share this post
Link to post
Yeti
They're not vibranium, they're unobtainium :)
  • Haha 1
Share this post
Link to post
dvderlm
Shame they don't do an 8 section box I could fit valves in too. The Etzold book says to use a "Farbstift". Is that a felt-tip-pen? I'll make sure to use pink for Cymro! Beats me how even permanent pen will get through the oil on the old ones.
What do they use at scrapyards?
Edited by dvderlm
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
  • Similar Content
    • Eilirthomas
      By Eilirthomas
      Hello guys im in the middle of my framboise red polo coupe build. Ive asked 3 local body shops and they do not have the paint code for the colour which is LP3D im in desprate need because i really want to keep the car the original colour because its so rare any help or links will be appreciated.
      (I have a build thread for my polo if you want to chevk it out)
      Thank you
      Eilir
    • POlliffe22
      By POlliffe22
      Does anyone have any suggestions for an alpine white rattle can. I tried the halfords one and the finish is nice but the colour is slightly yellower/ creamier that the factory paint on my '88 breadvan.
    • Eilirthomas
      By Eilirthomas
      Hi guys im resparaying my car in the original colour but have no idea where to get paint from! The code is LP30 or its known as Framboise Red can anyone help me please much appriciated
    • Mk2Haze
      By Mk2Haze
      Hey guys,
      Not been on here in a while but i hope someone can help.
      My Mk2 polo breadvan needs urgent attension with a few bits on her body work mainly the battery tray, i thought i could do it myself but running out of time as i relly want her to be my wedding car.
      Im loookig for trust worthy garage in the north east, someone that could possibly pick her up and look after her.
      Any help would be really appreciated
      Thank you :)
    • LukeBuxton
      By LukeBuxton
      Hey guys I am having some issue with rust on my arches of my 6n2. Could anybody supply me with a full list of supplies and a step by step method for sorting the rust using rattle cans if possible. If not what would I need for using correct spray equipment (I have nothing)
