Jump to content
MK2 4 speed linkage set up
Recommended Posts
NebulaicToaster
Anyone know how to set up the bolts on the coupling of a 4 speed MK2 gearbox, I can't seem to get the bolts tight and still be able to select all the gears. I don't understand the Haynes instructions to be honest. With the screw (right hand in pic) not fully tightened I can engage 3 & 4, but 1 & 2 are only available by pressing in the stick as if for reverse. Reverse cannot be achieved.  Any advice from someone who's done this before would be much appreciated.
1521476179286187690597.thumb.jpg.3b51650cc890320bf8077401797b3e00.jpgIMG_20180319_161753.thumb.jpg.0941081f1e17554d1a415ff7cd318511.jpg
Edited by NebulaicToaster
Link to post
Share on other sites
  • NebulaicToaster
    3
  • steveo3002
    1
steveo3002
the bolt on the right of your picture needs to be tight ..it tightens into a dimple and shouldnt be adjustable
then loosen the left side nut and bolt so that the clamp moves on the shaft..might want some wd40 on it ...with the gearbox in neutral get a helper to hold the gearstick where netural should be and tighten the clamp
if the gears do feel right keep fiddling until the they do...so box still in neutral..hold the stick to the left or right a smidge and try again
Link to post
NebulaicToaster
I'll give that a go in the morning. Cheers
Is it about the same method as this post?
Link to post
NebulaicToaster
Anyone know where to get hold of the 4 speed shift finger? 171711231A. I can't find it on eBay and the one I got doesn't fit, it's for the 5 speed later models
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Announcements
  • Create New...
