Jump to content
Brydo
9N3 1.2 12v Starting Troubles
Recommended Posts
Brydo
I'm starting to notice my 2009 9N3 sometimes has trouble starting. It did sit for a while and is now only starting to get used but sometimes I'm turning the key and it just turns but doesn't fire but always starts on the second attempt. I've rear horror stories online from 2007/2008 and on about the 1.2 12v having timing chain slip issues and a revised kit being available however my car is a late (09 Plate) model that was clearly manufactured after this issue being known. Could it still be the case? I hear that the timing can be checked with VCDS which my mate has, should I explore that?
I did also have this issue with the idle yesterday - revs were dropping very low when stopped at lights but that seems to have stopped for now. Not sure if it's related. Car only has 52K on the clock.
Share this post
Link to post
Share on other sites
Create an account
Register a new account
Sign in
Sign In Now
  • Create New...
