Jump to content
MonsterL35YFP
Cambelt tracking to one side
Recommended Posts
MonsterL35YFP
Hello polo people I post on here way to often at the moment but I'm having a slight issue with my cam belt it seems to be tracking to one side that much that the lip of the belt is just off the cam sprocket, now iv changed the water pump and belt plus the aux belt, my thinking is that the water pump is slightly off centre or iv tightened the aux belt to much. But just incase is there anything I can do to troubleshoot this? Cheers
Share this post
Link to post
Share on other sites
caretakerplus
I have seen this phenomena many times, and never quite worked out what causes it.
As you say yourself, the first thing to come to mind, would be that the pump sprocket (because that is the only one with flanges on it) is too far 'out' from the engine, but as it does not use a gasket, just an 'O' ring, it is difficult to imagine that it would in fact be out of alignment.
It would be easy to blame after market pumps, but I have seen this with genuine VW pumps as well.
The good news is, that they never seem to get any worse, although of course, it is as well to keep an eye on the belt wear.
I hope that you get a more definitive answer, as I am interested in that as well.
Regards
Share this post
Link to post
MonsterL35YFP
Yeah it's strange iv taken it on a long drive and doesn't seem to go past that point so I can't really see it coming off, I'm going to adjust the aux belt tension, I think it's abit over tight but I can't really see that being the problem, it's more of a irritat more then anything. So I'm hoping someone can give me some insight on what's causing it. Cheers for your help tho mate
Share this post
Link to post
kwijibo_coupe
I've seen this happen on a few of mine too. No idea what the cause or solution is. All I can say is it has never been the source of any issues in my experience. Just one of those slightly annoying Polo querks.
Share this post
Link to post
MonsterL35YFP
Well abit of an update the belt has started to rub on belt cover somewhere but the belt feels abit to tight so thinking of putting it back a touch see if it helps.
Share this post
Link to post
steveo3002
did it run true before you fitted new parts?
Share this post
Link to post
MonsterL35YFP
Yeah it was spot on
Share this post
Link to post
steveo3002
has to be the parts youve fitted then....pump on the skew /made badly
Share this post
Link to post
MonsterL35YFP
I would have said water pump so I'll take it off and see if it spins straight
Share this post
Link to post
steveo3002
guessing the bearing mount is slightly off so its not square to the engine ...or theres some crap under one of the bolts
Share this post
Link to post
MonsterL35YFP
So i let the tension off slightly it was a little tighter then i thought, took it for a spin down the road and it's back to one side, no going to lie really starting to piss me off.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
  • Similar Content
    • MonsterL35YFP
      By MonsterL35YFP
      Never been fitted lower strut brace, only selling because iv got a subframe on the way. Open to offers.
    • blue-polo-coupe
      By blue-polo-coupe
      After the breather pipe that goes out the crankcase into the oil separator what is the pipe that is supposed to come out of the oil separator, and where is it supposed to go?
    • Bennett Chef
      By Bennett Chef
      Hello... My Polo was broken into and steering column destroyed... so if anyone can help me with these parts i would be very gratefull🌝
    • fathands
      By fathands
      For sale is my Stainless steel exhaust that was custom made for my mk2 breadvan.
      Cat back system which consists of flexi pipe, centre silencer, and back box. Also 3 poly exhaust mounts and one rubber are included.
      The system was made by a company called custom chrome in Nuneaton and was designed to sit as high up as possible due to it being on a lowered car.
      The system is relatively quite (a bit louder than the standard system) during everyday driving but does give a sense of drama when you put your foot down. A really nice sound.
      Flexi pipe connection size: Internal 45mm external 49mm
      There is damage to the flexi pipe from scraping on speed humps and a small hole has developed as seen in the pics. The centre box also has some scrapes and dents. Also one of the clamps needs replacing.
      Local collection only
      https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F183410117686
    • fathands
      By fathands
      For sale are my recovered door cards in a fabric called black premium wool serge.
      They have homemade speaker holes that angle up and in towards the passenger and driver greatly improving sound quality.
      Fitted with Infinity Reference 6500cs speakers in full working order.
      I do have one grill, but unfortunately lost the other.
      To fit the front door cards they do require some fettling as they are too wide to fit into the plastic clips on the bottom of the door.
      I personally just put 2 screw through and into the metal of the door.
      Any questions please ask.
      Andy
