Jump to content
1vw2many
GT 4-2-1 exhaust manifold upgrade
Recommended Posts
1vw2many
Hi so over the weekend i managed to fit my 4-2-1 branch manifold on my gt and imasaf full exhaust system from Germany  and i must say its a vast improvement . So I'm looking on advice on what other improvements i can make ? Advice is welcome please.
Is it advisable that i use exhaust tape what ever its called on the 4-2-1 manifold ? might be difficult now its in but sure i can manage if needed.
Thank you.
Share this post
Link to post
Share on other sites
steveo3002
did it fit well/properly?  if so a link to the seller please
what improvements are you seeing
Share this post
Link to post
Guest 1vw2many
I brought it of someone on here , it has lamb socket and it fitted perfect. It just sounds better smoother etc.
Share this post
Link to post
kiran_182
A 270 cam and g40 injectors with an 8k ecu chip will liven it up but remember to adjust all the settings to make the most of them
Share this post
Link to post
1vw2many
Can i get any more gains if i just get 8k chip ? or does the cam also need fitting ?
Share this post
Link to post
kiran_182
The cam will make the most difference, the other things work along with it
Share this post
Link to post
1vw2many
Ok thanks lets see how much that little lot will cost.
Share this post
Link to post
kiran_182
If you go on the newman  website you can find it there 8v vw polo mk2 i think
They come up on ebay every now and then for 120ish 2nd hand
New tappets are always good too when swapping the cam, oil and rocker seal too
  • Like 1
Share this post
Link to post
1vw2many
Ok advice taken on board shall search for parts. Newman 270 cam is a road/rally cam ?
Edited by 1vw2many
Share this post
Link to post
steveo3002
newman will chat to you and reccomend something if you email them
be aware they do a shrink 268 copy if you ask for it
  • Like 1
Share this post
Link to post
1vw2many
I have emailed them so will see .
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
  • Create New...
