Jump to content
Mk2 polo breadvan 1984 febi gear selector lever repair kit install
Recommended Posts
Bevlesskeg
Hi all,
I can't find out how to install this febi gear selector lever repair kit. It has the ball joint, cup, top plate and bolts from the bottom of the gear lever. I can't get the old one off, because the plastic section that sits above it is in the way and cant go anywhere.
Any help possible?
Cheers!
Link to post
Share on other sites
  • Bevlesskeg
    2
  • dvderlm
    2
  • steveo3002
    1
dvderlm
https://volkswagen.7zap.com/en/rdw/polo+derby+vento-ind/po/1984-9/8/857-74000/
Screw 22 in that lets you remove gear-lever surround, once glovebox and driver side boxing are loosened or  removed - 4x phillps head screws 13 near top  and  2 small plastic locating pins either  side of gear-lever surround.
Edited by dvderlm
Link to post
dvderlm
Don't know, sorry. It will give better access to pull the stick  up, but you might have to remove the whole lot and mend it off the car.
I think there are 4 bolts that hold the mechanism to chassis, and the gearbox shaft is held by  a single m10 bolt.
So you will need to lift car (axle stand or ramp, not tyre change jack). Wiggling it past exhaust is also awkward.
Link to post
steveo3002
did mine off the car ...exhuast off , drop the box down , needs to come off to replace the orange bush at the front
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Announcements
  • Create New...
