Jump to content
9n3 Polo FSI coolant temperature sensor location
Recommended Posts
Decided to have a crack at replacing the sensor as it seems like a 2 min job, however being a complete noob, my brain was frazzled after opening the engine cover. Is the green thing in the photo the sensor? Any help would be appreciated, cheers.
Link to post
Share on other sites
  • nadz156
    2
  • nige8021
    1
Popular Days
Popular Posts
First Welcome to the forum.   That "Green" thing is the oil pressure switch, the coolant temp sensor will be on the thermostat housing, if you follow those thick rubber pipes back you will f
nige8021
That "Green" thing is the oil pressure switch, the coolant temp sensor will be on the thermostat housing, if you follow those thick rubber pipes back you will find the thermostat housing and it's #8 on this diagram https://volkswagen.7zap.com/en/rdw/polo+derby+vento-ind/po/2005-461/1/121-121075/#8
  • Thanks 1
Link to post
Thanks for the welcome and reply! Will have a look tomorrow morning, hopefully better luck next time.
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Announcements
  • Create New...
