Jump to content
Mk2 1.3 engine blown, best option for replacement
Recommended Posts
Nigel Baker
Hi all
The engine in my mk2 coupe s has just died, need some options for the best replacement. I am guessing that the engine from a mk2f will fit, but don't want to change too much wiring, so would I be able to run the mk2f engine with a carb? Any advice or ideas for good replacements will help. Thanks
Link to post
Share on other sites
  • Nigel Baker
    2
  • steveo3002
    1
  • kiran_182
    1
steveo3002
2f is basicly the same engine , although the cam has no fuel pump drive and the hole for the fuel pump isnt drilled in the head
Link to post
Nigel Baker
Not sure if it's terminal or not at the moment, will have too look into it when I get the chance. Basically made a loud clater on start up then ran ruff and very down on power. Looked into a few things checking fuel and spark etc. Try turning it over when it made the same sound only worse and then would not turn over. May not be terminal but defiantly not great !!!
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Announcements
  • Create New...
