Jump to content
Recommended Posts
I have a polo 1.4 9n3 16v. I am wondering if anyone knows how easy or hard it is to fit a turbo to my car. Obviously I wouldn’t be installing anything to crazy just a small turbo to boost my car. I have seen people saying this isn’t good for the car but surely a small turbo with all the correct additionals needed wouldn’t cause any major problems?
Link to post
Share on other sites
  • MatthewDey
    1
  • caretakerplus
    1
  • LR5V
    1
caretakerplus
Welcome to the Forum.
To start with, may I say that anything IS possible, but not everything is economically possible.
Fitting a turbo to your car, probably comes under the latter.
The most reliable engines with a turbo on them, are engines that have been designed to have a turbo.
For a start, your naturally aspirated engine will have a compression ratio that is too high to accept a turbo, so that would need to be lowered.
You also have the problem of arranging an oil supply and a return.
The fuel system may not cope with the extra air.
It is quite possible to overcome all of these problems and others beside, but as I said above, is it economically possible, or would it be better to have a larger engine, or even a larger car?
Regards
Link to post
its Hard
you may as well go crazy as the cost will be nearly the same.
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Announcements
  • Create New...
