Jump to content
Sign in to follow this
dvderlm
inlet valve to cylinder head port distance
Recommended Posts
dvderlm
Trying to work out the resonant length of my inlet tubes.
Think I've got :
  • 45mm trumpet
  • 112mm DHLA carb
  • 65mm VW motorsport inlet
Anyone know the distance or have  ideas how to measure the last part, side of head to inlet valve?
Think I might need much longer trumpets and plenum, or shorter trumpets to hit the high revs.
Share this post
Link to post
Share on other sites
dvderlm
Thinking about inserting a cable tie to closed cylinder 1 inlet valve above the carb throttle plate to find outer radius, then below throttle plate to find inner radius then use average of these
I estimate 5.5cm based on the 75mm bore and height of inlet port.
Edited by dvderlm
Share this post
Link to post
dvderlm
But maybe I need bigger chokes.
Performance Secrets book suggests
Think that should be:
  cc 6000 --- 7000 -- 8000 -- 9000 --  10000rpm
1000 23..25, 27..29, 28..33, 30..35, 32..36
1200 27..30, 29..34, 31..36, 33..39, 36..42
1400 29..31, 30..35, 34..39, 36..42, 38..45
1600 31..32, 32..37, 36..42, 38..45, 40..48
And the Weber guide chart with hand-drawn new curve (red)) could be 33 chokes for 7000rpm.
  • Like 1
Share this post
Link to post
LR5V
Hey that's some nice info you posted there -  the Performance Secrets book sounds interesting??
My only concern is you are looking for very specific accurate dimensions off a complete operational engine, something that I'm sure you will agree, is a lot easier stripped down on a bench.
Personally I would look into whipping the inlet manifold off to get accurate measurements of the port with  a vernier caliper and it will give you a more accurate view of the distance to the valve.
I recall a Dave Vizard article for port distance you need the distance along the centre of the port.
Share this post
Link to post
dvderlm
Used some plastic coated wire garden tie and stuck it in my spare head.
I reckon centre of the port to inlet gasket is 9.2cm.
So I have maybe 327mm inlet.
45+112+65+92 + (~3mm of gaskets).
Edited by dvderlm
Share this post
Link to post
dvderlm
45+112+65+92 = 314
(+ 3mm of gaskets?)
Share this post
Link to post
dvderlm
Having a go at 31mm chokes. These are 32mm chokes with some perforated exhaust tubing of 0.5mm wall thickness.
The flow will likely
be a bit turbulent, might even be awful for Bernouilli - but I can smooth the entry/exit, before having to up the jets again.
Now just need the wind to stop, dare not even lift the bonnet.
Share this post
Link to post
dvderlm
According to the formula for 2 litre Porsche  https://paul-abbott-hu7l.squarespace.com/throttle-body-and-main-venturi-sizing
and some coefficient guessing that allows (24.7mm to 35.8mm as answers)
((1.263/4*6200rpm) **0.5 ) *0.8 * 0.85 = 30.09mm venturi
and
((1.263/4*6600rpm) **0.5 ) *0.8 * 0.85 = 31.04mm venturi
and
((1.263/4*7500rpm) **0.5 ) *0.8 * 0.85 = 33.09mm venturi
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
  • Create New...
