Jump to content
Recommended Posts
mike1708
hii i have a problem with my polo 6n2 1.4 aud (gasoline engine) i try to activate cruise control via vcds and dose.t work i recive a error TO MANY COMUNICATION ERROR TO CONTINUE. have anyone a ideea. i am new with vcds and coding.
Share this post
Link to post
Share on other sites
Christian6N
Hope u get it working, cos a friend of mine has that engine in his lupo and he is interested in cruise control too.
But german forums says not possible on that engine. Do you have other/more informations about cc on the aud?
cheers
christian
Share this post
Link to post
mike1708
i see on a forum topic that is posible for aud engine i found the pins but is a problem when try to activate it. maybe a vcds problem i see others with same problem on abs module or airbag module...
Share this post
Link to post
nige8021
Have a look on this for your "Communication Error" http://www.ross-tech.com/vag-com/vag-com-faq.php  also there is no reference to enabling cruise with the AUD engine, but as it's a drive by wire setup I would of thought it was possible ?
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
  • Create New...
