Jump to content
Recommended Posts
Shaunzac
Have a 2004 1.4 Polo, failing mot on emmisions, o2 levels. Have changed cat, downstream lambda sensor, temp sensor and given full service. Any advice what else it could be, not showing any fault codes.
Share this post
Link to post
Share on other sites
caretakerplus
Is the air cleaner element in good condition?
I do get a bit concerned when people say that they have changed sensors - Fine if they have used genuine VW or Bosch ones, but there are some really cheap and nasty sensors out there, that might just be worse than the ones that they have replaced.
You could do worse than put a can of Wynn's injector cleaner in the tank.
Regards
Edited by caretakerplus
Share this post
Link to post
Shaunzac
Thanks for the reply, by cleaner element do you mean air filter, if so yes a new one and has also had injecter cleaner put through.
Share this post
Link to post
caretakerplus
Yes - Air cleaner element = the paper thing that fits inside the air cleaner housing.
Regards
Share this post
Link to post
Shaunzac
Yeah done that.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
  • Create New...
