Jump to content
Sign in to follow this
damunk
part number engine undertray
Recommended Posts
damunk
6N0825235H i was given this part number by vw for the undertray of a polo 16v AFH 1998
I have seen a 6N2 undertray for sale and the part number is same 6N0825235H
is the 6N1 and 6N2 chasis the same?
Also i have seen some from germany, i assume they wont work because of gear box etc on other side. think the undertray are designed with ventilation route in mind.
Share this post
Link to post
Share on other sites
nige8021
If you check on that part number site I have linked you many times, you will see they are the same for the 6N1/2
Also i have seen some from germany, i assume they wont work because of gear box etc on other side. think the undertray are designed with ventilation route in mind."  So if the the engine and gearbox were mounted the other way around, would that mean if you fitted a gearbox from a LHD you would end up with 5 reverse gears and 1 forward 🤣  The engine gearbox mounting is the same direction whatever side the driver sits on
Share this post
Link to post
damunk
much appreciated. worth asking considering they cost quite abit.
i did check that link u gave me  , its saved on my book mark. i coudnt find it on there. can you help me . its on 'body page'
Edited by damunk
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
  • Create New...
