Jump to content
1vw2many
Mk2f 91 GT engine cutting out
Recommended Posts
1vw2many
Hi my 91 GT cut out twice the other day while driving engine just cut out. I pulled over and it started back up.
I drove around another 5mins and as I slowed
down for traffic lights it cut out again but fired up straight away again .
External fuel pump was replaced around two years ago with an eBay special.
I must point out this is not a daily runner as I have another VW polo
Your thoughts and advice is most welcome.
Edited by 1vw2many
Share this post
Link to post
Share on other sites
nige8021
That sounds like the classic case of a failing hall sensor in the distributor
Share this post
Link to post
1vw2many
Is it easy job to replace nige ?Any links on a new one please ? Or maybe be better just replace the hole dizzy ?
Edited by 1vw2many
Share this post
Link to post
1vw2many
Yeah does look fiddly I might look at replacement of the hole unit price depending .
Thank you.
Share this post
Link to post
steveo3002
every hall sender ive had fail has become jerky as the car gets got , extreme jerkyness and the rev counter going mad , pot luck if it restarts or not
doesnt scream hall sender to me
if you do need to replace it best get a used genuine dizzy from a 6n...part number ending AB is suitable for the 3f , often £15 upwards on ebay when u search with the part number
Share this post
Link to post
1vw2many
Ok I did find hall sender at £50 but think I might go down the replacement dizzy from 6n .
Thanks steveo
Share this post
Link to post
1vw2many
As you said if it doesn't scream hall sender where do you think i should I be looking ?
Share this post
Link to post
steveo3002
dunno really
loose connections /dodgy wiring
did it die like the key was turned off or fade away ?  start instantly like nothing happened or struggle?
Share this post
Link to post
1vw2many
It died like key turn off. Started back up straight away no struggle.
Share this post
Link to post
steveo3002
id run it with the bonnet up and wiggle all the wires /connectors see if it will stop again
not saying the hall sender is a crazy idea ...just isnt the symtoms ive had , can often get a used dizzy for £15 so isnt end of the world to try one
  • Like 1
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
  • Create New...
