Jump to content
Eviljohn
Fuel smell mk2 breadvan
Recommended Posts
Eviljohn
Hi polo people. Hope you are well.
I'm hoping to get some guidance on the connections for the fuel tank on my mk2 breadvan.
Had a new tank fitted about a year ago. Ever since, been having smell of fuel when i put any in. As i don't always top it off, it's noticeable but not too bad. I topped it off yesterday and it's real bad. I checked the filler neck for leaks, all good, but smell is coming from around there for sure. There is a little outlet coming off the filler neck, near the top that has nothing attached to it. Should there be something on that?
According to the Haynes, i should have a small breather hose and a large breather hose. Should it be one of these?
Also, while checking for leaks, i found a hose behind the filler flap, coming in from above it that doesn't appear to be connected to anything. It's above the fuel tank so not sure it's anything to do with fuel. Can anyone tell me what it is?
Any pics, links or advice would be greatly appreciated as my brain hurts a bit.
Thank you very much for stopping by.
Take it easy.
Share this post
Link to post
Share on other sites
Eviljohn
Also, i took the inspection flap under the rear seat off. There is a hose connected to this that runs out to the side of the car but i can't see where it goes. This didn't smell, just wondering what the other end is connected to. The picture in the Haynes i have is hand drawn so is kinda helpful but could probly be clearer.
Thank you.
Share this post
Link to post
Eviljohn
Okay. I may have just figured it out but could do with confirmation if anyone can:
The little tube in the pic is the small breather hose, attaches to a small outlet towards the rear of the car.
The larger one that has nothin on it at the point is the large breather hose. Is this meant to be connected to the outlet under the back seat?
Share this post
Link to post
fathands
This should help
Share this post
Link to post
Eviljohn
Spank you. Number 7 is the culprit! Not connected to the filler neck. Got a funny feeling i'm gonna have to take the whole tank off to put it back on.
Thanks again.
Share this post
Link to post
nige8021
#7 is the jubilee clip the pipe is #6
Share this post
Link to post
Eviljohn
There's no jubilee clip and the end of the hose is not connected to the filler neck outlet. So 6 and 7.
Share this post
Link to post
Eviljohn
If i opt to replace the hose as i think it's just fractionally short, do i need to replace it with actual fuel hose or is it specific kind of hose?
The fuel hose i found with the correct ID is massive and i'm not sure it will fit under the bodywork without rubbing.
Share this post
Link to post
dvderlm
https://www.vwheritage.com/n0202903-breather-hose-per-meter-vw-spare
12mm internal 74+cm
(buy a meter - I could not remove the old hardened pipe.)
My replacement hose runs below seat , rather than below car (level sender cover only held on by one screw)
and through offside cavity and above original hose.
Breather so fuel fume safe, it's not in permanent petrol contact, unless you habitually  brim the neck by not inserting petrol pump filler fully.
Edited by dvderlm
Share this post
Link to post
Eviljohn
I don't think it's the oe hose. The filler neck end is proper grubby, matches the surrounding area. Fuel tank end is pretty clean. See through yellow tinted.
Thanks dude.
Share this post
Link to post
dvderlm
Fuel safe  PVC with wire reinforcement?
It'll turn yellow with age and fumes.
Share this post
Link to post
Eviljohn
Apart from givin me a headache, will it do any damage if it's not attached for a day or two? I'm not doin any long trips, just a mile or so round trip to work and back.
Share this post
Link to post
dvderlm
Only to the environment, but there's no charcoal capture system, and even that vents back to atmosphere if car not run to temp.
Don't pick up any smoking hitchhikers.
Share this post
Link to post
Eviljohn
Okay. Thank you guys very much.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
  • Create New...
