Jump to content
Vw Polo 93 issues with engine
Recommended Posts
Hi All.
I am getting upset with the issue that I am facing with my car. 1.0 engine petrol manual. After igniting the engine the rev is at approx. 1200 when it was 700. When I press gas to 1550 then release the revs drops to even 600 then jumps back. Mostly it happens on cold engine. Other thing. When I a. On 2nd or 3rd gear with rev on 2500-3000 then put into neutral the engine can switch off. 3 garages could not find the issue. Attached video with rev issue. Thanks. Luk
Ps I could not attached video so I upload it. Link here https://youtu.be/oXdHdJ8i62s
Link to post
Share on other sites
  • Sanbal
    1
  • caretakerplus
    1
caretakerplus
Welcome to the Forum.
There are several possible causes of your problem.
I would suggest that you buy a can of what we call here 'Carb Cleaner' - this is a solvent substance which you could use with a small stiff brush (old toothbrush) to clean the inside of the throttle body.
Don't be alarmed if there is a lot of exhaust smoke after doing this -  it will soon clear.
It might also pay to check the engine electrical connections for corrosion - often simply unplugging them and plugging them back in again will clean the connection, at least temporarily.
Regards
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Announcements
  • Create New...
