Jump to content
idle rpm
dvderlm
Recommended Posts
  • Replies 10
  • dvderlm
    9
  • Pete1
    2
So I think 10% more air flows through at 1050rpm versus 950rpm and carries more fuel despite being leaner mixture..
At !5.1 AFR there's hardly any CO but some NO2.
At 14.2 there's 2% CO I think.
At 15 it'll be quite hot-running too.
Wonder if I can get to a happy midpoint? It's eluded me so far twiddling mixture and speed. Perhaps one more idle bypass valve needs opening as well?
Slowest smooth idle and high vacuum is my usual goal.
Link to comment
Share on other sites
If you're only talking about those AFR's at idle, not across the range, then I don't think NOx or hot running will be an issue, as there's not enough fuel getting burned to cause high temperatures.
Link to comment
True,  but I don't expect the fan to come on in February and it did. Queue was not that awful and I turned engine off a few times before when at red lights.
Link to comment
Thought I had got it better than 14.2 like 14.4 by opening an idle  bypass valve on cylinder 2 which had highest vacuum with engine not quite fully hot and perhaps 900rpm.
But with headlights and windscreen blower on after a journey idle speed slowed and went richer.
So adjusted again and now at 14.9 to 15.2 and 1050rpm... It's almost as if there's something none analogue involved either side of 1000rpm.
I wonder if the Amethyst is doing something at that speed?
heating blower not rad fan
Link to comment
www.aldonamethyst.co.uk/Resources.htm
v1.80 firmware "No vacuum advance applied below 1,000RPM, and vacuum advance tapered off between 1,500RPM and 1,000RPM."
That will be it I think
So increase the static advance from 500 to 1000 by 1 degree?
Maybe I can upgrade the firmware to v1.11.0 which "Vacuum display now includes tapering off below 1,500RPM" so I can see the true taper effect..
Link to comment
Pushed advance at 500rpm to 8 with 1000rpm at 9. degrees plus the vac advance , which improved a bit.
Then offset the whole map by 1 degree and it has smoothed out.
Idle mixture screws in a bit, speed screw out to reach 750 and still ticks over.
Settled on 950rpm and 14.9:1 AFR.
Not fully warm but that is encouraging. Amethyst says it is running at 16 degrees advance.
Twin carbs need more.
Need to measure with a timing liight... I think it actually had only 10 degrees advance by the gun last time.
The +1 offset means Max Total Advance is now 1 + 5+32 = 38.
Link to comment
Here's the "centrifugal" advance curve if anyone is using another programmable ignition.
Link to comment
The graph does not show the +1 offset...
or the 5 static
or the vacuum related extra advance which is quite crude as this is the turbo Amethyst.
One day...
Link to comment
Actually drove it some distance today without any queues. Felt like 28 days after a massive epidemic 😁 and before the zombie hordes 💀.
Once really hot idle had hit over 1000rpm on the over-reading dash tacho so loosened the speed screw about 1/8th of a turn and it is now great. Probably 900rpm.
Anyway, that is the smoothest it has felt in motion for ages. Pulling away does not stumble any more below 1300rpm, which I'd kind of got used to. Exiting roundabouts gently is now possible in 3rd gear, speed bumps (which I still dread due to lowness) can be approached and glided over with no clutch slipping.
Hope it survives until the Rolling Road day. There's an MOT to get through first.
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Create New...
