Jump to content
Not good news for anyone running a Pre 2011 car the introduction of E10 petrol
Recommended Posts
  • Replies 9
  • zob
    3
  • dvderlm
    2
  • DerekR
    2
  • nige8021
    1
Popular Posts
Hi - I just managed to confirm that an old girl (1.4 8v 6n2) WILL be compatible with E10 - confirmed by VW.  (Per Yeti above) - I understand that there is a 2002 - 2006 version that is not compatible
dvderlm
Having fought ethanol / water encrustation in the carbs once, I'm using about 45ml Startron per tank when car is likely to sit for a while, and I have switched fuel feed line to Teflon lined (exceeds SAE J30 R9), apart from the last section from pump to carbs. Better do that too.
I suppose the increased Ethanol of E10 will provide some charge cooling for boosted engines, but at all loads.
Note:
My feed line was already not original VW after someone stole fuel by slicing it during the fuel protests (2000?). I used stainless braided caring more about the outside than the part in contact with the petrol.
  • Like 1
Link to post
Share on other sites
I remember there was a good thread chatting about this a year or so ago, if memory serves the main talking points were:
  • Premium unleaded won't have the same requirements for minimum ethanol content so there should be petrol at an E5 rating still available, albeit more expensive and thus effectively a 'tax' on those who can't afford a newer car
  • Replacing hoses, o-rings, seals for more ethanol-friendly materials could mitigate a lot of problems in the right cars
  • Using a fuel additive like 'ethanol shield' etc should help, although adding extra cost and being a pita to remember to use
The other option is to dangerously separate out ethanol from the fuel in the garage like I do with the lawnmower but treating 2l of gas at a time is frankly scary enough.
Link to post
Thats the stuff! Maybe there's legs in making a stickied list of approved things we can do to mitigate future issues?
Link to post
3 minutes ago, zob said:
  • Premium unleaded
As usual i got this the wrong way - in the uk its Super Unleaded is the actual premium fuel, premium unleaded is standard
Link to post
Apologies if you guys have murdered this subject already.  I am just trying to find out whether a year 2000 6n2 1.48v is compatible with e10 or not.  Shell's superdooper 99 octane e5 is a bit costly!
Thanks all
Link to post
dvderlm
Can you ask a VW dealer and report here?
I fear you'll need to use E5 super.
VW after 2002 are mostly okay for E10.
EXCEPTION
First generation FSI not suitable for E10.
Polo 1.4 FSI (63 kW) made from February 2002 to June 2006 (model year 2002 -
2006).
https://www.acea.be/uploads/publications/ACEA_E10_compatibility.pdf
Link to post
As I read it,  it's only engines direct injection engines (FSI as VW call them). The 1.4 8V in your car pre-dates the VW FSI engines (it came in in the 9n's from about 2002 onwards), so there shouldn't be a problem as long as your fuel isn't sat in the tank long enough to start absorbing moisture from the air that's in there, but that's going to take months.
Link to post
Hi - I just managed to confirm that an old girl (1.4 8v 6n2) WILL be compatible with E10 - confirmed by VW.  (Per Yeti above) - I understand that there is a 2002 - 2006 version that is not compatible but thereafter again compatible.  8p to 10p per litre extra to buy the whizz bang e5 feels like an attack on the less wealthy to me.
Thanks all for your interest - I called 0800 333666 if anyone needs VW to confirm this stuff.
Edited by DerekR
  • Thanks 1
Link to post
  • nige8021 changed the title to Not good news for anyone running a Pre 2011 car the introduction of E10 petrol
Create an account
Register a new account
Sign in
Sign In Now
Announcements
  • Create New...
